backspacing help w/ narrowed rearend??? - Chevelle Tech
post #1 of 2 (permalink) Old Aug 29th, 05, 10:21 PM Thread Starter
i was wondering if anyone has put 17 x 13 on a 69 chevelle, w/ a narrowed rearend? the rearend is narrowed 2inches on each side. i had it done because i wanted to run the stock ss 14 x 7s w/ the largest tire i could find, which was the m. t. indy profile L60-14. however, now that i have more money i would like to try to get 17 x 13s on there. i saw someone had used 6.25 backspacing, but is that w/ a stock width rearend? any help would be appreciated. thanks guys
younggun396 is offline
post #2 of 2 (permalink) Old Aug 29th, 05, 10:55 PM
Re: backspacing help w/ narrowed rearend???
My car has 17x13's but it's also been backhalved w/full tubs. Its Fab 9 rear is 56" wide,,6" narrower than stock.
So,you're going to need narrowed frame rails and wider wheel tubs to run that wide of a rear wheel,IMO.
Clint44 is offline
This Thread is more than 5422 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
12-bolt rearend width questions THE DUDE 2001 16 Sep 4th, 11 12:54 PM
fourlink coilover with narrowed 9" ford rearend, tubbed sean jackson Brakes, Suspension & Steering 7 Apr 28th, 05 11:37 PM
backspacing on new wheels Aaron 2004 9 Dec 12th, 04 4:17 PM
Help with backspacing on new wheels Aaron Wheels & Tires 0 Dec 5th, 04 8:26 PM
Just double checking backspacing before I order wheels. PatrickM Wheels & Tires 4 Jul 2nd, 02 9:39 AM
