1968 Chevelle Rear Wheel Backspacing Question? - Chevelle Tech
post #1 of 11 (permalink) Old Oct 30th, 17, 4:18 AM Thread Starter
Gabe
Hey guys, anyone know how much backspacing can be put into the rear rim on 1968 Chevelle with a stock 12 bolt. I'm having a set of wheels custom made and I know the norm is 5.5" but from what I see I think it would be better to put a bit more into it say 5.75" or 6.0" but the lower shock is going to be getting very close to the lip of the rim, any info appreciated.
OURSS396 is offline
post #2 of 11 (permalink) Old Oct 30th, 17, 4:40 PM
Clint
Re: 1968 Chevelle Rear Wheel Backspacing Question?
What width and diameter wheel?
Clint Hooper
Sold
Sold
Clint44 is offline
post #3 of 11 (permalink) Old Oct 30th, 17, 7:55 PM Thread Starter
Gabe
15" rim 10" wide.
OURSS396 is offline
post #4 of 11 (permalink) Old Oct 30th, 17, 8:24 PM
Clint
15" rim 10" wide.
There's a good reason 5.5" backspace on a 15x10 wheel is considered the gold standard, Gabe. In this particular case, more probably isn't better.
Clint Hooper
Sold
Sold
Clint44 is offline
post #5 of 11 (permalink) Old Oct 31st, 17, 1:48 PM
Greg.
Drum Brakes or the Wider Disc Brakes ?
There are ways to Adjust/move the Rear Lower Shock Mount Bolt
so it does not interfere with the Rim of a 15" x 10" Wheel with a 5.75" /6.00" BackSpace
One way is to use a Round Headed Bolt to attach the Lower part of the Shock to the Bracket
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #6 of 11 (permalink) Old Nov 17th, 17, 10:28 AM
Glen
I have 5" backspace on my 15" x 10" wheels 295\50\15 tires and it rubs the outer wheel well if I hit a bump.
1968 Chevelle
468 Big Block
Muncie M20 4 Speed
12 Bolt Posi 3.31:1 Gears
glend123 is offline
post #7 of 11 (permalink) Old Nov 17th, 17, 10:34 AM
rick
I have 9.5"X17" with 255/50/17 on the back of my 68 without rubbing if that helps you any
shovelrick is online now
post #8 of 11 (permalink) Old Nov 17th, 17, 12:22 PM
The shock mounting isn't the only problem. You can run into the inner wheel tub on bumps if you're car is lowered because the clearance isn't exactly vertical and there is less clearance in the upper portion. I have 5.5" backspacing and occasionally rub on the inner tub with 275/60s. My wheels are 9" wide and also very close to the outer lip. I can just about fit one of my sausage fingers in there. I don't rub on the outer lip, though, just the inner. My car is lowered 2" in the rear. I have new and stiff poly bushings in UMI lower control arms and Edelbrock adjustable uppers that won't deflect like stock arms with rubber bushings. I think if I had stock bits it would rub every which direction on off-camber bumps.
70 Camino...Roller
Tommy the Cat is offline
post #9 of 11 (permalink) Old Nov 17th, 17, 4:26 PM
Clint
Rick, what's the backspace on those 17x9.5's? If it's anywhere close to a 0 offset (5.25"bs), those wheels will easily fit, especially with a narrow 255 tire.
Clint Hooper
Sold
Sold
Clint44 is offline
post #10 of 11 (permalink) Old Nov 17th, 17, 4:45 PM
Clint
Tom, 15" tires tend to have their own fit problems because of their taller, more flexible sidewalls. They need to have more side clearance, to allow for the extra sidewall flex. My 70 is lowered 2" in the rear, has 20x10's w/5.75"bs (+6 offset), 305/30/20's, yet no clearance issues inside or outside. Rear suspension is all stock, for now. It does have rear disc brakes but if they widened the rear track, it is very minimal.
Clint Hooper
Sold
Sold
Clint44 is offline
post #11 of 11 (permalink) Old Nov 17th, 17, 7:44 PM
rick
Sorry I forgot to add my BS, it's 5.5", frnts are 8"X17" 4.5" BS with 245/45r17
This Thread is more than 803 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
