Fueling up in California - Chevelle Tech
  • 1 Post By zombie1969
post #1 of 10 (permalink) Old Aug 21st, 17, 2:44 PM Thread Starter
Vern
I will be driving down to California next month. The car I will be driving has a recessed filler neck and about half the time I can not get a good seal over the filler neck. If I inserted a transmission funnel into the filler neck, then the rubber fill nozzle would be tight against the funnel, would this make a good enough seal to fool the pump?
suntreemcanic is offline
post #2 of 10 (permalink) Old Aug 21st, 17, 3:15 PM
Re: Fueling up in California
I haven't had a problem with any car, new or old, since those things were new to the market. That's been around 30 years.
Steve R
Steve R is offline
post #3 of 10 (permalink) Old Aug 21st, 17, 3:20 PM Thread Starter
Vern
My filler neck is way down into the fender and it sometimes can not make a seal. I have been going to California for many years and this has been an on going problem with this car. Just trying to find a solution for this trip.
post #4 of 10 (permalink) Old Aug 21st, 17, 7:15 PM
In my Chevelles, I rarely get a good seal (you can often hear the liquid pouring in)... Although I do have a problem with the shorter hoses many station use now... That said, I usually have to hold the nozzle into the filler neck (but the trigger is kept on "automatic")...
TC #1366
Sold
Sold
1966_L78 is offline
post #5 of 10 (permalink) Old Aug 21st, 17, 7:39 PM Thread Starter
Vern
Is there a vacuum created when the rubber fill nozzle fits against the fuel filler neck? Does there have to be a vacuum for the pump to work? My problem is on a 52 Buick Super.
post #6 of 10 (permalink) Old Aug 21st, 17, 9:20 PM
AKA Zombietroll
It's for vapor recovery so the ozone layer doesn't fall on are heads. The pumps in ct and ma don't use those anymore. All you need to do is compress the spring enough so the pump thinks it's sealed it a pain when filling a jug because two hands are needed.
Steve R likes this.
zombie1969 is offline
post #7 of 10 (permalink) Old Aug 22nd, 17, 12:09 AM Thread Starter
Vern
I wonder if they use that spring type system in California? If they do then my idea with the transmission funnel would work. Does anyone in California know if they use that spring system?
post #8 of 10 (permalink) Old Aug 22nd, 17, 12:56 AM
yes... just pull the rubber part of the pump that rests on the filler neck back towards you slightly and you'll be fine
Big Cheps is offline
post #9 of 10 (permalink) Old Aug 22nd, 17, 1:02 AM
Eddie
X2 You'll be fine. I'm in SF Bay Area, pumps here are using that spring system.
Eddie K is offline
post #10 of 10 (permalink) Old Aug 22nd, 17, 9:46 AM Thread Starter
Vern
Great!!!!Thank you. I can work around the spring.
This Thread is more than 1011 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
