A/C questions, newer car - Page 2 - Chevelle Tech
 5Likes
post #16 of 20 (permalink) Old Jun 29th, 20, 4:32 PM Thread Starter
Well, I just tried starting the truck cold so the heater isn’t a factor... no cold air, 95 at the vents before starting and after... truck is sitting in the sun.
I did notice the sound and airflow changed when switching from Cold to Hot ( Blue to Red), which would seem to be the blend air door functioning. I could clearly hear the air flow change. I could feel it but not as apparent.
Didn’t matter which vents; dash/ floor/ defroster... all had the same noticeable change in sounds from Cold to Hot or Hot to Cold...
I put the orifice tube and a few other pieces in my “cart” for Rock Auto. Not going for a compressor or anything expensive now...
I am also going to visually check for leaks. I already had a small bottle of oil and a Pringle’s kit and the receiver/ dryer ( accumulator?)
But the project is on hold for now. I have too much on my plate, and only tried because I had the manifold gauges for the Camry..
Thanks everyone
TC #1366
Sold
Sold
1966_L78 is online now
post #17 of 20 (permalink) Old Jun 29th, 20, 7:19 PM
Re: A/C questions, newer car
28PSI suction pressure is way too low for normal operation.
Freezing pressures temperatures of low side and refrigerant
*** R12 factory fitted GM systems that use suction throttling valve [POA valve ] operate at 30PSI
***R134a freezing pressure temp 28 psi
In modern systems As automotive systems are a total compromise ie have variable suction line pressures due variable engine RPM constant rpms pressures are a myth . The thermostat saves the modern evaporator from freezing . The Tx valve plays a role but to a lesser degree.
At idle the compressor is hardly working . Pressures need to be taken at 1200rpm or higher . Often the TX valve can be seen operating and often during thermostat cycling the low side will dip well below 30psi all be it briefly .
Car makers use the low pressure cold temps [below ideal] to assist cooling. Many evaporators are to small for the job . This saves the car maker money .Effectively cheating the system .
Well designed systems donot have compromises and work very well in ALL ambients .
Operating pressure ideally ,,not always achieved
Low.... no lower than freezing pressure/temp of refrigerant
High... relevant to how hot ambient is,, ideally = 115f = 150-160psi
swampy 6x6 is offline
post #18 of 20 (permalink) Old Jun 29th, 20, 9:07 PM
You obviously haven't charged up a R134a system using the suction pressure as a gauge.
I've usually always evacuate the system and weigh the charge in and with the exact amount in, the suction pressure is NEVER even down close to 28 psi on a R134a system.
You seem to talk about everything except what these threads/posts are actually about which only confuses folks.
There is no expansion valve (or R-12) in a modern orifice tube R134a system.
LeoP likes this.
post #19 of 20 (permalink) Old Jun 30th, 20, 6:09 AM
HI
Dean the OP was in question as to what Low/high pressures should be . So yes it was discussed .
Servicing A/con is way way more than squirting refrigerant in . Did u no that auto aircon comes inboth t/X valve and orifice tube !!. Even in the same model of car R12 or R134a .
I guess with an EPA government refrigeration license and experience of 35years plus ,might just no some thing !!
I have explained superheat and subcool together with other parameters on how to properly charge a system in other threads . I suggest u read these b4 u comment in future .
Oh yea a tx valve system is commonly filled to subcool and superheat spec using the low/high pressure gauge!! Many car makers donot due to to smaller condenser but u new that !!
I guess u new all about the freezing temp that's why u mentioned it !! Many auto systems can operate around 30 psi on the low side very successfully .
post #20 of 20 (permalink) Old Jun 30th, 20, 9:02 AM
Tell me all about it.
LeoP likes this.
