2000 Astro Van Pitman Arm Nut Size... - Chevelle Tech
 6Likes
LinkBack Thread Tools
Old Sep 12th, 19, 11:36 PM Thread Starter
I have the unfortunate job of changing out the power steering gear on my mom's 2000 Astro van. Does anyone here know what size wrench/socket I need to get the pitman arm nut off with?? The Astro van site I am on has not been much help.
I also discovered once I had everything removed to get to the steering gear (air box, fan shroud, hoses, etc.), that the stupid power brake booster is also leaking. I think I invented some new swear words today...
My Chevelle w/ open headers:
WakkoWarner is offline
Old Sep 12th, 19, 11:45 PM
mike
Re: 2000 Astro Van Pitman Arm Nut Size...
11/4 I think, you will likely need a puller for that arm as well.
slowmo55ss is offline
Old Sep 12th, 19, 11:47 PM Thread Starter
My 1 1/4" wrench is too small.
Old Sep 13th, 19, 1:50 AM
mike
Sorry, been awhile, going from memory.
Old Sep 13th, 19, 5:37 AM
36mm if I remember correctly.
67-468 is offline
Old Sep 13th, 19, 8:06 AM
...you will likely need a puller for that arm as well.
And a torch, and a hammer, and planets to align properly, good luck!
Pioneer4x4 is offline
Old Sep 13th, 19, 8:44 AM
It took a 40 ton hydraulic press to remove the Pitman arm when I did my 70 El Camino steering box. It just laughed at a 20 ton press.
B52bombardier1 is offline
Old Sep 13th, 19, 6:13 PM
Andy
It's 1 5/16
71350SS likes this.
Andy's Auto Repair is offline
Old Sep 13th, 19, 8:42 PM Thread Starter
Originally Posted by Andy's Auto Repair View Post
It's 1 5/16
Thanks. I found that out when I finally got the steering gear out of the vehicle (you have to remove it before you can take the pitman arm off). I just happened to have a socket that size, along with a 1/2" adapter. I actually took both steering gears to a machine shop that I use for brake rotors and drums. We got it removed from the old, installed on the new one, and I torqued it down (unfortunately, this resulted in my Craftsman Digitork torque wrench no longer clicking).
I got everything reinstalled and it all works (I had to change out the power brake booster, too, as it was leaking). So, new steering gear, new power brake booster, and 3 new power steering hoses. The down side is that the hose that goes from the booster to the steering gear is seeping just a tiny bit at the connection point. I am going to wait to put a new o-ring on it until it gets quite a bit cooler during the day. But, it is working, with no major leaks - I am calling it a victory.
LeoP and Andy's Auto Repair like this.
Old Sep 13th, 19, 9:17 PM
Andy
Did you forget the idlers?
71350SS likes this.
Old Sep 13th, 19, 11:34 PM Thread Starter
I replaced both idler arms about a year ago with the Moog problem solver units.
LeoP likes this.
Old Sep 14th, 19, 12:02 AM
I hate working on Astro vans. The company I worked for had several, one an AWD model. Nothing is easy to get to.
63 Nova wagon
Philip is offline
Old Sep 14th, 19, 12:33 AM Thread Starter
It is the bane of my existence. She is on a fixed income, so I have to keep it running as long as I can. The engine is fine, the transmission does its job, and the AC is cold. All of the interior plastics, however, are deteriorating. I may not be able to find that stuff much longer.
Old Sep 14th, 19, 8:24 PM Thread Starter
Update: I popped the hood this morning and checked that connection - it was dry. All of the other connection points were dry as well. So, I think it may have been residual fluid on the thread from when I put the hose in. I will keep an eye on it, but I think it is leak free (for now).
LeoP likes this.
Old Sep 14th, 19, 11:12 PM
leo
Damn Brian, we just traded in our 2009 Grand Caravan with 171000 well kept miles on it and even though you live far away, it would have been a good one to get for your Mom. I did all the maintenance to it except the water pump, engine gaskets and front struts, they were done under warranty back in march. always a day late and a dollar short!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
Thread Tools
