1994 Cavalier non tilt how to remove ignition switch - Chevelle Tech
post #1 of 4 (permalink) Old Sep 9th, 19, 1:50 PM Thread Starter
From what I read..you have to remove the steering wheel first..how does this happen..does the pad come off someway first?by pulling on it?
TC #0672
1972 SS 454 M22
"W " Code Midnight Bronze
Bandit1978 is offline
post #2 of 4 (permalink) Old Sep 9th, 19, 3:58 PM
Jonathan
Re: 1994 Cavalier non tilt how to remove ignition switch
I assume you are talking about the key cylinder???? The true electric ignition switch is farther down the column.
IIRC they snap on.
Go to Autozone and rent a steering wheel puller. You will also need a tool to depress the plate so you can remove the C clip. after that it is a piece of cake as long as you have the key to turn the lock cylinder.
Two 72 Chevelle Malibus, both 350 2bbls one Placer Gold, one Midnight Bronze
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
Chevelle_Nut is online now
post #3 of 4 (permalink) Old Sep 9th, 19, 5:14 PM
Jon N.
Removing Cavalier lock cylinder.
Jon N.
dyno jonn is online now
post #4 of 4 (permalink) Old Sep 13th, 19, 2:26 PM Thread Starter
Just thought I would share my story on this..Problem When the car key was turned to start the car..it wouldn't start because it wouldn't stay in the run position.just fell back to the off.so I had to get it home with holding the key manually in the run place..to get to the ignition module first disconnect the battery..take the bottom cover plastic cover off..remove the horn button pad..disconnect the horn wire by twisting the connection.remove the steering wheel...remove the left plastic cover holding the turn signal and the right one holding wiper arm you will see 2 screws holding the plastic column covers to remove it..I failed to see them and broke the plastic tabs on the column cover..unplug the elect connections for the ignition module and then unbolt the module..Cost me $38 ..good thing the key cylinder wasn't bad it would have been 169 dollars..plus you have to drill out 2 holes to get at the screws..my car didn't have a airbag so if yours does you have to disconnect it first before starting..thanks for all the help..
TC #0672
1972 SS 454 M22
