'05 Express 2500 Fan Clutch - Chevelle Tech
 5Likes
  • 1 Post By EdCarpenter
  • 1 Post By LeoP
  • 2 Post By paul bell
  • 1 Post By shovelrick
post #1 of 8 (permalink) Old Jun 28th, 19, 6:43 PM Thread Starter
rick
I'm trying to get the fan clutch off the water pump, it doesn't have 4 bolts like most the fan clutch hub holds the WP pulley on but mine just keeps spinning even when I jammed wood, rubber etc. in between belt & pulley, I see a small hole in the pulley is that to stick a tool or nail or something to keep it from turning, another mechanic friend said he used air chisels to knock them loose then they spun off easily, I tried a hammer & chisel with no luck and also it's probably not good for the new pump, other mech. buddy changed WP less than a year ago, wish I knew we should've changed the fan clutch then, TIA rick
shovelrick is online now
post #2 of 8 (permalink) Old Jun 28th, 19, 11:35 PM
leo
Re: '05 Express 2500 Fan Clutch
There are tools to do that operation. good luck!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #3 of 8 (permalink) Old Jun 29th, 19, 12:27 AM Thread Starter
rick
Hi Leo, I rented the tool kit but it's for the 4 bolt pulley, mine doesn't have bolts and all parts stores that rent the tool kit are all alike that's the reason I was asking if there's another way or another tool that I need to buy? going to try putting an allen wrench in the hole tomorrow and will let you know how it goes, youtube has nothing
post #4 of 8 (permalink) Old Jun 29th, 19, 9:24 PM Thread Starter
rick
Well rental tools for removing the fan clutch didn't work out, drove the van 10-12 blks to a friends house he's a semi retired mechanic and after struggling with the rental tools he knocked it loose with an air chisel so that's another way to get'er done, didn't take any pics of knocking it loose with the air chisel but I'm sure you can get the idea
ID:	596950   Click image for larger version
ID:	596952   Click image for larger version
post #5 of 8 (permalink) Old Jun 29th, 19, 10:18 PM
Use an air chisel. It will break it loose and you can spin it off by hand.
shovelrick likes this.
Ed C.
70 SS L34 Auto project
57 Belair hardtop project
Always looking
EdCarpenter is online now
post #6 of 8 (permalink) Old Jun 29th, 19, 10:31 PM
leo
As a retired Mechanic myself, the shop had the tools and I purchased my own to use when I did side work. Sometimes a pipewrench and a BFH works as well. I have had two Chevy's that had that fan clutch. Glad you found someone to help you!
Leo Paugh
A.C.E.S.#3731
LeoP is offline
post #7 of 8 (permalink) Old Jun 29th, 19, 10:38 PM
The correct tool is this spanner wrench. You use it to hold the pulley and a big open end wrench turns the fan nut. I own one, it works. The wrench on the fan nut usually needs a smack with a BFH.
https://www.lislecorp.com/specialty-...spanner-wrench
LeoP and shovelrick like this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #8 of 8 (permalink) Old Jun 29th, 19, 11:03 PM Thread Starter
rick
I rented the spanner wrench & big wrench but it was really stuck I'm surprised because I had the WP changed less than a year ago, air chisel to the rescue Oh and I used plenty of anti seize on the new one
LeoP likes this.
