1997 Chevy S10, A/C not working - Chevelle Tech
  • 1 Post By Dean
post #1 of 2 (permalink) Old Jun 24th, 19, 5:53 PM Thread Starter
Where should I start?
Thinking I should get a pressure gauge and see if there is anything in the system. If low, then add some (with dye)... Or, can I just quickly depress the schrader valve with a key/screwdriver to see if there is any pressure?
But if its empty, should I add some dye first (before evac?), to find the leak? Or is that dangerous without evac (high pressure head?)...
I ordered new o-ring kit and a new rec/dryer in anticipation. of replacing something...
I had a cracked line replaced a few years ago (four years?), but the A/C quit working last year, but I put it off. I only put 100-200 miles per year, but summers are brutally hot...
TC #1366
Sold
Sold
1966_L78 is offline
post #2 of 2 (permalink) Old Jun 24th, 19, 6:05 PM
Re: 1997 Chevy S10, A/C not working
Yes, you need a set of gauges.
IF there is zero pressure in the system it needs to be evacuated BUT I would add a little refrigerant to pressurize the system and check for leaks first.
IF there is some pressure in the system but low, check for leaks first.
Those compressors are bad about leaking where the front and rear end bells are sealed to the center body of the compressors.
Of course you could just charge it up every so often like a lot of people do, depending on how fast it leaks down.
LeoP likes this.
