1995 gmc3500 454 - Chevelle Tech
 3Likes
  • 1 Post By Schurkey
  • 2 Post By LeoP
post #1 of 9 (permalink) Old Mar 9th, 19, 11:40 PM Thread Starter
1995 gmc3500 454
What should my truck be idling at and what should oil be at on gauge. Has 178196 miles on her
Biospider is offline
post #2 of 9 (permalink) Old Mar 10th, 19, 3:19 AM
Justin
What is your truck idling at and what is the pressure at idle when hot and at cruise when hot? Have you seen a decrease in oil pressure recently?
JF74chevelle is offline
post #3 of 9 (permalink) Old Mar 10th, 19, 5:46 PM Thread Starter
It idle's at 1000 rpm and oil is about 35 to 40 pounds and when Crouseing it is about 70 pounds
post #4 of 9 (permalink) Old Mar 10th, 19, 5:47 PM Thread Starter
And that is when it is all hot and ready
post #5 of 9 (permalink) Old Mar 10th, 19, 6:59 PM
Re: 1995 gmc3500 454
Idle is way high, or tach is inaccurate.
Oil pressure is normal-to-high, or gauge is inaccurate.
Steve R likes this.
Schurkey is offline
post #6 of 9 (permalink) Old Mar 10th, 19, 7:30 PM Thread Starter
What should I have idle at
post #7 of 9 (permalink) Old Mar 10th, 19, 9:23 PM
My Gen VI idles at around 600 - 700. Your pressure is fine if your gauge is good, which is actually rare. 10psi per 1000rpms is the rule of thumb, so anything above 10psi at idle is technically OK as long as it rises with revs. Nothing I own or drive drops below 30psi at idle and two of them have well over 200K on the ticker.
One of the reasons the big block Chevy is so popular is its almost bulletproof oiling system. I've had good luck with Gen VI stuff with priority main oiling. I don't know that it'll ever come into play, but I like the peace of mind knowing that if I lose a lifter, the mains will still receive pressurized oil.
Gary Adrian
Busted Knuckles is offline
post #8 of 9 (permalink) Old Mar 18th, 19, 1:59 AM
Is that 1000 RPM reading in Drive or is that a Park/Neutral RPM ?
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #9 of 9 (permalink) Old Mar 19th, 19, 12:18 AM
leo
You may have a throttle body base gasket leak, spray some carb cleaner around the base of the throttle body with the engine running and see if the idle calms down, good luck!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
Flat top 454 or domed 427 for a rering job Jim Mac Engine 11 Apr 10th, 17 1:36 AM
454 with oval port build gmw468 Performance 22 Oct 12th, 16 9:34 AM
01" 502 Vs 94" 454 build for my A-body Sebambam Performance 3 Sep 7th, 16 11:24 PM
is it worth it to leave my 496 in or put the 454 back in? Whittaker What's it worth? 16 May 20th, 16 2:56 PM
question about BBC heads davec5 Engine 16 Jan 5th, 13 11:03 PM
