How To Reinforce Cheap Plastic... - Chevelle Tech
 5Likes
  • 2 Post By Pioneer4x4
  • 1 Post By hrspwrjunkie
  • 1 Post By fishhead
  • 1 Post By WakkoWarner
post #1 of 10 (permalink) Old Mar 5th, 19, 9:32 PM Thread Starter
I have to replace the door lock/window switch panel on the passenger side in my mom's Astro van again (luckily I was able to find a brand new one that didn't cost a fortune). These things are made from the cheapest crap plastic known to mankind - I don't even think the plastic in a Yugo is this cheap.
Anyway, I am looking for suggestions on a way to reinforce 2 of the mounting points, to help prevent them from breaking (the 2 mounting points I need to reinforce are where the bolts for the inside door handle go through). If anyone has any ideas, your input will be greatly appreciated. Thanks in advance.
ID:	588116   Click image for larger version
ID:	588120   Click image for larger version
My Chevelle w/ open headers: http://www.youtube.com/watch?v=Q61TTYXmIsc
http://www.youtube.com/watch?v=YFm_ISn_UDA
WakkoWarner is online now
post #2 of 10 (permalink) Old Mar 5th, 19, 10:32 PM
Bruce
Re: How To Reinforce Cheap Plastic...
You can buy thin plastic sheets at most Hobby Shops. Cut them to fit and superglue them down? -or- A thin (fiberglass) resin (only) reinforcement layer?
NickeyChevelle is offline
post #3 of 10 (permalink) Old Mar 5th, 19, 10:33 PM
leo
can you find some plastic washers and glue them on??
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
www.mdchevelleclub.com
LeoP is offline
post #4 of 10 (permalink) Old Mar 6th, 19, 1:49 AM
Epoxy putty.
David
http://www.cardomain.com/ride/307290...rolet-chevelle
davewho1 is offline
post #5 of 10 (permalink) Old Mar 6th, 19, 3:55 AM
Al
I don't know if this will work or if it's even what you are asking,
A Common fix for the door pull cup is to fab a piece of aluminum or steel to fit the bottom of the cup, drill the 2 screw holes and mount it up. This reduces the strain on the rest of the door parts/trim when the door is pulled closed.
DUTCH MAX HEADWORK is offline
post #6 of 10 (permalink) Old Mar 6th, 19, 7:27 AM
If you reinforce with more plastic, don't use superglue, use plastic model cement that acts like a solvent and they melt together. You can also plastic weld more on the back. Personally I would look to metal mesh/epoxy/fiberglass type of reinforcement after bending a piece of steel to match the plastic further in to the panel, not just at the first bend.
71350SS and LeoP like this.
Pioneer4x4 is offline
post #7 of 10 (permalink) Old Mar 17th, 19, 12:09 PM
Ryan
Polyvance who used to be Urethane Supply Company, sells kits for both tab replacement and reinforcement (PlastiFix and FiberFlex, if my memory is correct). I've used them successfully in a number of repairs in my '93 Mustang years ago.
It may also be possible to get really creative and use a plastic repair kit and stainless wire mesh if you need lots of strength.
427L88 likes this.
hrspwrjunkie is offline
post #8 of 10 (permalink) Old Mar 17th, 19, 8:27 PM
Shane
J B WELD.
Everything else is garbage.
71350SS likes this.
1969 chevelle
fishhead is online now
post #9 of 10 (permalink) Old Mar 17th, 19, 9:15 PM
blm
This is very similar to my idea. I would use Aluminum and JB Weld it to the backside. Maybe .032 gauge Aluminum.
blm is offline
post #10 of 10 (permalink) Old Apr 2nd, 19, 1:10 PM Thread Starter
Strength isn't the issue - it is just crappy plastic that cracks from being in the Arizona sun. The door handle attaches directly to the door steel, so it is not creating stress on the plastic. The lower door handle bolt does go through the hole on the plastic. Polyvance recommended their PlastiFix product, along with glass fiber cloth. I just ordered the PlastiFix (from someone other than the manufacturer, which allowed me to find a $5 off discount code - so I saved $21 total on the product), now I just have to find the glass cloth at a reasonable price.
hrspwrjunkie likes this.
1968 dash plastic???? 68 garret Interiors 5 Aug 1st, 18 11:46 PM
70-72 plastic inner fenders 1971ss454Elco El Caminos 2 Jul 25th, 18 2:43 PM
plastic fender wells 1neat69 Chevelle Tech 8 May 31st, 13 3:25 PM
plastic clips for 1969 headliner Chris R Interiors 0 Feb 24th, 13 7:55 PM
Plastic masking sheet. 427stingray Body Shop 1 Feb 10th, 13 1:32 PM
