1995 C3500 454 OBD1 questions - Chevelle Tech
 6Likes
  • 1 Post By Iforgot
  • 1 Post By ZZ69chevelle
  • 1 Post By Iforgot
  • 3 Post By Iforgot
post #1 of 15 (permalink) Old Feb 4th, 19, 1:44 AM Thread Starter
Greg
A little background- I’m familiar with RS232/422/485 and have a bag full of various network adapters (most have FTDI chipsets)..
Now my questions: I’d like to get into the ECM of my 95C3500 454 TBI. Long story short, about to put headers, a small cam, etc to try and get more towing power and want the ability to change timing maps, etc.
Looking on the interwebz, downloaded Tunerpro RT. Rigged up a cable to my OBD1 port per diagram (interestingly, interwebz indicated my 95 should have an OBD2 style plug but system is still OBD1. Mine has an OBD1 plug. Hasn’t been changed, I bought this truck brand new in ‘95..)
Now my Only problem is my usb>serial port RS232 converter won’t do 8192 baud..I can see it starts trying to communicate (LEDS) then drops out. ?? What baud rate do I set my Win7 serial port!? Tried setting port @ 9600 and TPSoftware @ 9600, didn’t work either.
Next, what’s needed to change parameters on the ECM chip? Am I going to have to drop $350 on all the EEPROM burning stuff (I.e. Moates) or what?
If that’s the route I have to go, TBI/intake/ignition will end up in the bottom of a lake and I’ll put a carb and HEI on it..
Anyone have some input?
Greg C.
1969 Chevelle Malibu
New 496 bullet under construction..
Iforgot is offline
post #2 of 15 (permalink) Old Feb 4th, 19, 7:27 AM Thread Starter
Greg
After not being able to sleep because I couldn’t figure out what was happening, I got up and started researching.
Figured out why I couldn’t connect to it yesterday. Duh!
Also know about the EPROM that supposed to be in the ECM now, where and how to get a blank chip or emulator, and how to burn a new EPROM.
Biggest thing I learned is that the more I learn about EFI, and these automotive controls, the greater my love for a Holley carb and HEI becomes!!
And that’s coming from a fella that works as a Building Automation Systems Engineer!!!
B52bombardier1 likes this.
Greg C.
Iforgot is offline
post #3 of 15 (permalink) Old Feb 4th, 19, 7:36 AM
Re: 1995 C3500 454 OBD1 questions
Some of those supposed FTDI chipsets in the adapters are often cheap Chinese clones of Prolific chipsets. And they are not particularly good copies.
I went through this problem a while back when computers stopped having real, no kidding hardware Comm ports for Comm 1. I need this so that my PC computer can talk with the computer inside my Icom HF radio - I'm a ham / amateur radio operator.
Sent from my SAMSUNG-SM-N900A using Tapatalk
B52bombardier1 is offline
post #4 of 15 (permalink) Old Feb 4th, 19, 7:44 AM
Originally Posted by Iforgot View Post
After not being able to sleep because I couldnít figure out what was happening, I got up and started researching.
Figured out why I couldnít connect to it yesterday. Duh!
And thatís coming from a fella that works as a Building Automation Systems Engineer!!!
What was the problem. I have fought many COM port battles in the past, but luckily not in quite a while. Last time was to console into an older smart networking switch. I think I used 3 different adapters and about 2 hours to get it to communicate.
Pioneer4x4 is online now
post #5 of 15 (permalink) Old Feb 4th, 19, 9:46 AM Thread Starter
Greg
Well, seems there wasn't one...forgot to connect everything THEN turn key to acc, etc...oops.
Also- using one of the RS232/422/485 converters we have here at work, VSCOM - USB to Serial: VScom USB-COMi-M is what we have. FTDI it's got external DIP switches to select RS232/422/485 and internal removable jumpers for pulldown-pullup-termination bias-3.3v power supply or 5v power supply on-off-etc. FTDI chipset, nice little device. Haven't found very many devices it WON'T talk to!
That said, there's probably more knockoffs out there that are not FTDI chipsets that wreak all kinda havoc. Haven't got a COMi-M device yet that was fake-or at least was fake and I didn't know it.
Even used one to fix the communication link at the dragstrip between the ET ticket printer and the Tower last year!
Greg C.
Iforgot is offline
post #6 of 15 (permalink) Old Feb 4th, 19, 10:15 AM
Gary
I know what I would do if I were you. I would bolt some 96 and later Vortec l-29 cylinder heads on that thing with a q jet and an HEI. If I wanted fuel injection I would probably go with a new aftermarket system from Holley. easier to tune faster more capable ecm. i dont see why you couldnt use an aftermarket ecm to run the stock system as far as that goes as long as the injectors are compatable. If you still want to use the stock system there are people out there still burning proms. i would check with ed wright at fast chip
gnicholson is offline
post #7 of 15 (permalink) Old Feb 4th, 19, 10:33 AM
terry
Gearheadefi.com has a good bit of support for those who are going to work on the older stuff...
mytmouz is offline
post #8 of 15 (permalink) Old Feb 4th, 19, 3:46 PM Thread Starter
Greg
That was my original plan!! Then I caught so much flack about taking off this wonderful fuel injection, figured what the heck. That said..
I was planning on burning my own chip, but honestly the deeper in this I dig the worse (expensive) it looks. Plus keeps getting more complicated!
I mess with enough sensors and “ecm’s” from 7-4 every weekday.
Sure leaning back towards throwing this fine TBI in the lake and following the KISS principle ESPECIALLY since it’s a NV4500 manual trans!!
Greg C.
Iforgot is offline
post #9 of 15 (permalink) Old Feb 4th, 19, 4:29 PM
Gary
i wouldnt take it off if it was the newer port injection. its not that the 87 to 95 tbi systems are bad . i wouldnt want to burn a prom for every change i wanted to make for one thing. the tb doesnt flow alot of air. good ol qjet and hei are hard to beat
post #10 of 15 (permalink) Old Feb 4th, 19, 4:51 PM
I did a lot of prom burning with my TPI third gen camaro, then started to with my 89 TBI stepside. While I made improvements tuning it, it wasn't worth the effort compared to doing a carb/HEI swap. I never looked back. It was a pita. Scan while driving, upload data, analyze, make changes, burn new chip, drive and scan, upload, analyze, make changes, burn another chip, repeat, repeat, repeat. TPI could get to light right up without excessive cranking, TBI always seemed like a dry carb first start of the day no matter what I did. That was my biggest complaint. I used to use Tunercat and a pocket programmer II, but I think Jet bought Tunercat out. Life is supposed to get easier as we get older, not harder.
Hotwire likes this.
ZZ69chevelle is offline
post #11 of 15 (permalink) Old Feb 4th, 19, 8:16 PM Thread Starter
Greg
You read my mind.
Been out here TWO AND A HALF HOURS. Got connected to it finally, but it's got so many variables that depend on other variables that depend on other variables..
Thought I fried it a few minutes ago. Turns out I didn't tighten th e negative battery cable good..
I could be inside the shop running valves on a restored 64 Impala SS 425/409/2 4's.
But NOOOOOOO I'm out here chasing 30+ year old tech that was no better than the 60 year old tech it replaced.
TBI WILL get thrown down the hill and used for target practice.
ZZ69chevelle likes this.
Greg C.
Iforgot is offline
post #12 of 15 (permalink) Old Feb 4th, 19, 8:27 PM
Don't shoot it up just yet. I got $125 for my 454's TB from a guy upgrading a small block TB.
post #13 of 15 (permalink) Old Feb 4th, 19, 11:22 PM Thread Starter
Greg
Heck with it. Impala sho is purtier!!
1964 SS, 425HP 409, 4 speed, two fours, got to run valves, little tune up, niiice car!
ID:	585426   Click image for larger version
ID:	585428   Click image for larger version
ZZ69chevelle, 68-13427 and Hotwire like this.
Greg C.
Iforgot is offline
post #14 of 15 (permalink) Old Feb 6th, 19, 11:31 AM
Sure leaning back towards throwing this fine TBI in the lake and following the KISS principle ESPECIALLY since itís a NV4500 manual trans!!
Funny you should mention the nv4500, I didn't know they came behind gas burners in GM's. I have a couple of diesel spec 2wd 4500's sitting around, spares for my dually. They are truly the "little" transmission that could-I've laid down some decently stout torque through those with no breakage. I even have one with an aftermarket bellhousing adapter for use behind a chevy. I guess your factory bellhousing does that.
'71 chevelle, 468, TH400, 12 bolt posi w/3.08's, drinks a lot of 87 octane.
v8440 is offline
post #15 of 15 (permalink) Old Feb 6th, 19, 3:55 PM
The nv4500s are very popular with the 4wd crowds. They bolt to anything and are dang near bullet proof.
I came in on the LT1 tuning, 92-95s, and had my fair share of fun with RS232 ports and adapters. One of the weirdest problems I ran into was my rs232 port on my laptop didn't have enough output to keep the MAX232 chip happy. Ended up having to add a voltage regulator and power the adapter off the cigarette outlet.
I've heard of some success stories w/ the Moates Ostrich cable but heard it could be a pain too. If you do decide to get into it, this may be a isolated case, but my buddy had Moates piggyback memcal board and kept having problems with it running. Brought it to me, found the piggyback board had bad solder joints.
Good luck!
*Jeff*
LQ4 / T56 Swap Project Thread
Hotwire is online now
454 Tuning Questions pockets Performance 0 Jun 25th, 13 7:15 PM
Truck 454 Build up Questions man44a Performance 6 Mar 12th, 13 9:42 AM
454 Build questions ohlson67 Performance 9 Feb 20th, 13 2:47 AM
72 chevelle 350 to 454 build questions bigcheese_20 Projects & Builds 10 Jan 19th, 13 1:03 AM
piston questions for 454 1978chad454 Performance 4 Oct 21st, 12 3:21 PM
