Trying to find axle stamping on a Camaro 12 bolt.. - Chevelle Tech
 2Likes
  • 1 Post By Saltherring
  • 1 Post By X-77keith
post #1 of 12 (permalink) Old Feb 2nd, 19, 2:50 PM Thread Starter
Guys, in moving my old junk to my new home , I looked really hard to find axle stamping on a 12 bolt rear axle I removed from a 68 Z 28 back in 1974. All the Chevelles have the stamping just to the left of the main hub. The number 2 is the ONLY stamp I can find on the entire axle. Do we know IF those axles were stamped at all . I assumed they were all made in Buffalo at that time and thought I would at least find that stamp. The Z cars had a torque rod bracket welded on...could it have been under there. thanks for any info.....
BanditRX is offline
post #2 of 12 (permalink) Old Feb 3rd, 19, 9:33 AM
Don
Re: Trying to find axle stamping on a Camaro 12 bolt..
I thought just the "67" HP Camaro's Z/28,L78 ect. (monoleaf) used the torque (radius) rod? "68"s went to multileaf springs and staggered shock's. Not a Camaro guy so someone correct me if I'm wrong.
Don B is offline
post #3 of 12 (permalink) Old Feb 3rd, 19, 10:58 AM
Ole
I do not remember a "torque rod bracket" on '69 Z/28 Camaros. I worked on many of my friends' cars and none had this to my recollection.
The axle stamping should be on the forward radius of the passenger side axle tube, about one foot outboard of the pumpkin.
Name:	Dad 1969 Z28 Camaro .jpg
Steve R likes this.
Saltherring is offline
post #4 of 12 (permalink) Old Feb 3rd, 19, 9:20 PM Thread Starter
I will check again in that area real good....will get out the wire brush. Not sure on the 67 and 69 Z s but I saw several 68 Zs with the torque rod. I KNOW this is a factory 4.10 posi from the 68, but with no stamping no way to prove it. Wished I had of gotten the whole car. The owner lost it one nite and centered the drivers door in to a telephone pole. Floor boards and roof pretty crushed. That could have been fixed today but back then we just scraped them. He had sold the motor, tranny by the time I got there. I took out the 12 bolt, clutch pedals, hideaway head lights, real tail lights and speed/tack gauges. A real X car....but O Well....
BanditRX is offline
post #5 of 12 (permalink) Old Feb 3rd, 19, 9:36 PM
KEITH
Don is correct. 68/69 would not have a torque rod. That was only a 67 thing. X. Codes did not come around till 69. I have. Had 29 Camaro's. Currently I have a X77. If the rear was indeed out of a 68, it was welded on after the car was purchased new. The rod would not have been beneficial on a 68 though.
Steve R likes this.
X-77keith is offline
post #6 of 12 (permalink) Old Feb 4th, 19, 7:36 AM
Look here: 1967-69 Camaro Drivetrain Decoding
buenymayor is offline
post #7 of 12 (permalink) Old Feb 4th, 19, 7:44 AM
Don
Thank's for verification Keith,I've got a friend with 4 Camaros,68Z,two 69Z's,69 COPO and he just purchased an original 67 L78 and it's the only one with the torque(radius)rod.
Don B is offline
post #8 of 12 (permalink) Old Feb 4th, 19, 9:01 AM
KEITH
The torque rod was a early fix for axle wrap. It was a mid year, maybe a little earlier tban that fix. The dealer would install it if you complained. Some 67's can be found without them, but they are few and far.
post #9 of 12 (permalink) Old Feb 4th, 19, 11:49 AM Thread Starter
No X cars till 69, no torque rods after 67, seems I KNOW so much these days about things that just ain t so...ha ha. I love this site with so many that are fact checkers and keep us armed to true accounts. I do thank you for correcting me when I'm in error. Did some digging thanks to buenmayor s post and found out I have a 67 12 bolt, cast C 31 7, code QL, a 3.31 non posi, that was assembled May 08 , 2nd shift by Detroit Gear. stamp 05 08 G2. I was told by PO it was the original rear and I believed he believed it was. I removed the series 4 Eaton posi unit and the ring and pinion are GM gears stamped with a late 67 date. Ovuously someone built this axle for some heavy hammering prior to.
X77, thank you much. My plain Jane 67 Camaro , 210 327, power glide , 10 bolt has no radias rod bracket. Obviously it did not need one......do you know when they were used....12 bolt big block cars or certain gear ratios used or high hp engine combos. My older drag racer friend had a shop out back I use to hang out with. I remember seeing several 68 Zs cars in there for work, all small block cars that had the radias rods , and just assumed they were factory.....now I know they were added..thanks again.
BanditRX is offline
post #10 of 12 (permalink) Old Feb 4th, 19, 3:04 PM
Jon N.
Camaro Research Group
All the Camaro info you are likely to need about 67-69 Camaros.
Jon N.
dyno jonn is offline
post #11 of 12 (permalink) Old Feb 4th, 19, 5:28 PM
Ole
Most (all?) of the '67 Camaros came equipped with mono leaf rear springs. SS 396 models had a single traction bar on the passenger side. I recall riding in an L35/T400 convertible back in '68 that was so equipped. I can't recall ever seeing a documented, original '67 Z/28 so I'm uncertain of the spring configuration. Most '68s, again, were mono leaf. '69 SS cars came with 5-leaf rear springs and the Z/28 with 4-leaf springs if I remember correctly. Many guys back then ran rear slapper bars like my brother-in-laws former car, still owned by the guy he sold it to in 1973. The photo below is of the same car as the one I posted above, but this one is from last summer. Note the Ansen Ground Grabber bars, bolted on by the car's original owner in 1969.
post #12 of 12 (permalink) Old Feb 4th, 19, 5:39 PM
KEITH
If i recall the arm was a big block thing. Some dealers would ad them to whatever. The mono leaf was still used through 69. The 68 Z/28 had 4 leaves like in 69. So no need for the arm. The CRG is full of this kind of info. If im not mistaken the arms were put on a lot more firebird than Camaro's. The X codes came out in 69, and was only on the Norwood cars. The Van Nuys cars had no X codes at all. The rear you have has value. Drum to drum they are going for North of $2K.
1967 Chevelle 12 bolt axle perches? Jsanford1974 Transmission & Driveline 3 Aug 11th, 15 12:13 AM
70 Malibu rearend axle question 12 bolt stroker55 Transmission & Driveline 8 Jul 20th, 15 1:23 AM
Garage find 69 Camaro RS SS conv. 65chevelle300post Bench Racing 21 Mar 20th, 15 7:15 PM
Where to find a left hand thread bolt??? Tan66Elkie Bench Racing 12 Oct 15th, 12 2:01 AM
12 bolt axle 67RAT 1999 -- 10 Jun 28th, 99 8:10 PM
