I have a 2012 Chrysler Town and Country head light recomendation - Chevelle Tech
 2Likes
  • 1 Post By Schurkey
  • 1 Post By SSR71
post #1 of 8 (permalink) Old Jan 25th, 19, 4:46 PM Thread Starter
I am wanting to upgrade the headlights on the van to see better at night in the rain and such..so many types out there..can anyone steer me in the right direction for ease of installation and best one..without getting crazy on the price?
TC #0672
1972 SS 454 M22
"W " Code Midnight Bronze
Bandit1978 is offline
post #2 of 8 (permalink) Old Jan 25th, 19, 5:31 PM
Re: I have a 2012 Chrysler Town and Country head light recomendation
FIRST, verify voltage AT THE BULBS. If you have less than 12.8 volts with the lights on, engine running and alternator charging, fix the wire harness. Voltage should be between 12.8 and 13.2. Higher voltage than 13.2 will brighten the lights, but shorten headlight life. Verify that there's NO voltage on the ground wire. Repair as needed.
SECOND, verify that the headlights are aimed properly.
THIRD, verify that the headlight covers aren't cloudy. The NHTSA should issue a recall on EVERY vehicle sold in the USA that has cloudy headlights. Since they won't, it's up to you to make sure the crappy plastic lens remains clear.
FOURTH, verify that the headlight reflectors are still in good condition. I replaced a bunch of sealed-beams because they still worked--but the reflectors were in such bad condition that half the light was shining backwards into the headlight bucket.
AFTER you've done all that, and the lights aren't bright enough for you...try some different bulbs. There's aftermarket incandescent replacements with higher wattage (but not DOT legal, of course) and then there's a whole pile of cheap-crap Chinese "HID" and "LED" stuff, which probably won't work properly with the reflectors you have.
Chevelle_Nut likes this.
Schurkey is offline
post #3 of 8 (permalink) Old Jan 26th, 19, 12:39 AM
leo
Some folks like the Sylvania Bright Star headlight bulbs!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #4 of 8 (permalink) Old Feb 10th, 19, 2:02 PM
Kevin
I agree that checking the wiring would be the first step. However, I'd be rather shocked if a 2012 vehicle was still running headlight power through the entire harness and not through relays located up near the rad support.
That would be Silver Star. The "Ultra" are the higher grade. They also have the "ZXE" line that emulates the HID spectrum... and I'm sure are quite a bit more $. I've been using the GE Nighthawk line on my truck after having too many Silverstars burn out within months. They too are in multiple grades. I use the "Platinum". They've been holding up quite well for me but may not be quite as good as the Sylvania.
https://www.bulbfacts.com/halogen-bulbs/recommended/
Based on that site's testing, the OSRAM Night breaker bulbs were the brightest. And I will likely be going with them for my SSR (assuming they have appropriate bulbs). But, better bulbs will only help so much. The fact is that these modern headlight assemblies are total crap from day 1 because they're made for aero and visual appeal, not function. The SSR is a good example - not the best throw and a horrible cutoff. The Silverstars were definitely an improvement (GE didn't have a matching bulb), but they're still lacking.
LeoP likes this.
2017 SS
1972 El Camino Custom
2005 SSR 6-speed
1999 Silverado
SSR71 is offline
post #5 of 8 (permalink) Old Feb 10th, 19, 3:48 PM
Cory
Once again...Schurkey knocks it outa the park.
dream66 is online now
post #6 of 8 (permalink) Old Feb 11th, 19, 8:35 AM
How many miles/hours are on the factory bulbs. I had a 2002 T&C Limited that was the best vehicle I ever owned (from style, comfort, usability... nothing like hauling a lawn tractor or 17 sheets of drywall behind you with your butt in comfortable suede trimmed leather captains chairs). Pretty much my only complaint from new was poor headlights. I ended up putting in the best/most expensive over the counter bulbs in for kicks. I believe they were the Sylvania Ultras. They made a very noticeable difference. Also I filled in the rebate form, so now I am a "registered" owner of the bulbs, and I got some check or mail or something from a class action law suit that they mis-represented the bulbs performance or some BS. All I know is they helped, and I was pleased. Try them, try either just plain cheap new bulbs, or splurge and get the best you can find. It will only cost you a tank of gas.
Pioneer4x4 is offline
post #7 of 8 (permalink) Old Feb 11th, 19, 8:43 PM
Kevin
That's also a good point. All incandescent bulbs will degrade over time. When I got around to upgrading the bulbs on my SSR, the high beam bulbs (which obviously see far less usage) had a noticeable brown tint to them from internal oxidation. I wish I had taken a picture of them before tossing.
2017 SS
2005 SSR 6-speed
1999 Silverado
SSR71 is offline
post #8 of 8 (permalink) Old Feb 11th, 19, 8:46 PM
Andy
The TIPM (Total Integrated Power Module) that powers those bulbs are around $1200 installed. If you NEED an upgrade, upgrade the van.
Want to mess with that TIPMs constitution, go aftermarket bulbs.
This coming from the guy that does this stuff every day.
And yes, Shurkey is a poet.
Andy's Auto Repair is offline
