2000 Astro Van Weird Brake Issue... - Chevelle Tech
 4Likes
  • 4 Post By WakkoWarner
post #1 of 15 (permalink) Old Jan 22nd, 19, 2:02 PM Thread Starter
Not too long ago, I put new brakes on the front my mom's 2000 Astro van, complete with new rotors. At the start, everything was fine. Now they have gotten a few hundred miles on them, they have developed a weird pulsating sound. The sound also is 'rough' (best way I can describe it). The rotors themselves are fine - no rough spots or indication of metal to metal contact. The pads that I put on were the Durlast GT52 pads and the rotors are AC Delco long life units.
Today I swapped the pads out for a set of the Wagner Thermoquiet ceramics. I took it for a drive and the noise has been greatly lessened, but it is still there. Does anyone have an idea on what might be causing it. The rotors spin freely and I can not feel any rough spots. The only noise is from the dang plastic housing for the ABS (attached to the backing plate). It rubs just a little, but all of the rotors that I have ever used have done the same thing without making this new pulsating sound.
If anyone has any ideas, your input will be greatly appreciated. Thanks in advance.
My Chevelle w/ open headers:
WakkoWarner is online now
post #2 of 15 (permalink) Old Jan 22nd, 19, 2:09 PM
Re: 2000 Astro Van Weird Brake Issue...
Can you feel the pulsating in the brake pedal?
If you lend someone $20, and never see that person again, it was probably worth it.
Molly's 70 is offline
post #3 of 15 (permalink) Old Jan 22nd, 19, 2:28 PM Thread Starter
No pulsating in the pedal at all - it is steady and smooth. I am wondering if it was created because the GT52 pads are really more of a performance oriented pad (I run the same ones on my Chevelle) and that they did something weird to the rotor. It is significantly quieter now. I told her to go easy on the brakes for the first 50 or so miles, so maybe it will straighten out - who knows.
post #4 of 15 (permalink) Old Jan 22nd, 19, 2:33 PM
Did you use a torque wrench to tighten the wheels?
post #5 of 15 (permalink) Old Jan 22nd, 19, 2:48 PM Thread Starter
Never have and it has never been an issue. As I stated in my previous post, it was fine until a few weeks ago - no noise at all when I had everything installed new.
post #6 of 15 (permalink) Old Jan 22nd, 19, 3:14 PM
Yea, I thinking the pads. Maybe they didn't get seated good enough. You'll get better help than me soon. LOL
post #7 of 15 (permalink) Old Jan 22nd, 19, 3:58 PM
Swap pads from one side of the car to the other. If it goes away, great. If it stays, rotor or wheel bearing. If it moves, pads.
Pioneer4x4 is offline
post #8 of 15 (permalink) Old Jan 22nd, 19, 4:01 PM
What type/brand rotors? You can get warped rotors even when they are new.
ZEN357 is offline
post #9 of 15 (permalink) Old Jan 22nd, 19, 5:01 PM Thread Starter
I just put new pads on it this morning - the old ones are not on the vehicle.
Per my original post, the rotors are AC Delco.
post #10 of 15 (permalink) Old Jan 22nd, 19, 10:55 PM Thread Starter
I may pull the new rotors off on Friday morning and get them machined (I hate to have to do that to new rotors).
post #11 of 15 (permalink) Old Jan 23rd, 19, 1:34 AM
Wheel hub?
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #12 of 15 (permalink) Old Jan 23rd, 19, 9:26 AM Thread Starter
Originally Posted by paul bell View Post
Wheel hub?
The rotors attach just like Chevelle rotors. When the calipers are removed, the rotors spin freely with no rough spots. With the calipers installed, you just hear the noise from the pads as you spin the rotors (normal).
post #13 of 15 (permalink) Old Jan 23rd, 19, 9:31 AM
I usually buy the platinum pads and rotors from Advance Auto. I have had pretty good luck with them.
ZEN357 is offline
post #14 of 15 (permalink) Old Jan 23rd, 19, 6:41 PM
OH SORRY. It's the AWD version that has wheel hubs.
How may I help you?
1999 Trans Am-500hp
post #15 of 15 (permalink) Old Jan 23rd, 19, 9:02 PM Thread Starter
I got freed up today, so I pulled the rotors and took them to the machine shop. When I went to pick them up, he said that one of them had some pretty decent warp to it. On the way home, I went ahead and purchased inner and outer wheel bearings, since I really don't know how long the current ones have been in there (the old bearings actually look really good).
I noticed that it was the ABS ring on the rotor that was scraping the plastic, so I tapped it down a bit which helped a lot (I did it to both of them, since they were both making contact). I took some emery cloth to the new brake pads, as they had some weird black coloring from operating on the unmachined rotors for some errands.
Once I got it all buttoned up, I took it for a drive. The brakes are very smooth and QUIET. We'll see how these Wagner Thermoquiet brake pads hold up over time.
427L88, LeoP, paul bell and 1 others like this.
