2005 Chevy Trailblazer Electrical Issue... - Chevelle Tech
 2Likes
  • 2 Post By WakkoWarner
post #1 of 5 (permalink) Old Jan 2nd, 19, 3:56 PM Thread Starter
My friend has a 2005 Chevy Trailblazer. Recently, it started have a weird electrical issue. They will be driving along and it will lose power for 1 to 2 seconds - the AC will turn off, lights will dim, and the radio will turn off. The battery connections are tight. Where should we start looking to track this gremlin down?? If anyone has any ideas, your input will be greatly appreciated. Thanks in advance.
My Chevelle w/ open headers:
WakkoWarner is offline
post #2 of 5 (permalink) Old Jan 2nd, 19, 4:26 PM
gary
Re: 2005 Chevy Trailblazer Electrical Issue...
Possible ignition switch. Chevrolet Trailblazer Ignition Switch Problems - part 1
post #3 of 5 (permalink) Old Jan 2nd, 19, 8:42 PM
Rich
I'd also look at the BCM. Make sure the connections to it are good, tight and clean. It could also be that the BCM itself is starting to fail.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is online now
post #4 of 5 (permalink) Old Jan 19th, 19, 11:59 AM Thread Starter
We changed the ignition switch and installed new O2 sensors (the dang parts stores all told him that it had four O2 sensors, when it only has two - inline 6 engine). The engine is running better now (he says it is a lot smoother) and the vehicle has not lost power since the ignition switch was changed. So, we are going to call it a victory for now. Thanks for the input.
LeoP and 1967 chevelle malibu like this.
post #5 of 5 (permalink) Old Feb 10th, 19, 2:54 PM
Kevin
Those switches are usually the culprit 90% of the time. Shared with the SSR (it's a trailblazer chassis and drivetrain) and most of us carry a spare around at all times because of it.
However, the '05 SSR also experienced an issue that would only happen after heat soak under the hood - a wire within the fuse box fatigue cracks over time and the heat finally causes a full separation. After sitting long enough to cool down, it'll restart and run again. From the description, this doesn't sound like the problem though - which is good. It's an expensive repair.
2017 SS
1972 El Camino Custom
2005 SSR 6-speed
1999 Silverado
SSR71 is offline
