2000 Chevy Astro Intermittent Wipers... - Chevelle Tech
 3Likes
  • 1 Post By Hotwire
  • 1 Post By WakkoWarner
post #1 of 8 (permalink) Old Jan 2nd, 19, 2:37 PM Thread Starter
I was driving my mom's Astro van in the rain the other day. The intermittent wipers were not performing as they should. Sometimes they would work on delay, other times they would run constantly. Is this problem most likely going to be in the stalk switch or in the motor itself?? If anyone has any ideas, your input will be greatly appreciated. Thanks in advance.
My Chevelle w/ open headers:
WakkoWarner is online now
post #2 of 8 (permalink) Old Jan 2nd, 19, 3:14 PM
Re: 2000 Chevy Astro Intermittent Wipers...
If it's anything like the S10/blazer wipers, it's the wiper motor board. They sell replacement boards, but it's usually cold solder joints on the larger metal pieces of the board. There's 3 T10 or T15 holding the cover / board in the wiper motor housing, pull the screws, pull the board, resolder the bad joints, I usually push the wiper arms out a hair while I'm in there, and put it back together.
Hope this helps!
LeoP likes this.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #3 of 8 (permalink) Old Jan 2nd, 19, 3:22 PM
gary
If it is the board you can try tapping on it to see if it affects the problem. The boards were the most likely problem with the wipers.
post #4 of 8 (permalink) Old Jan 2nd, 19, 3:50 PM Thread Starter
I can get a board from Autozone with a lifetime warranty on it for $35. I think I will go that route.
LeoP likes this.
post #5 of 8 (permalink) Old Jan 3rd, 19, 9:44 AM
Good luck, just put something under the wiper motor when you start taking the screws out. They're deceivingly short and disappear in a hurry.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #6 of 8 (permalink) Old Jan 3rd, 19, 10:11 AM
Just curious are you sure it doesn't have rain sense? I know 2002 Envoy could have it.
Pioneer4x4 is offline
post #7 of 8 (permalink) Old Jan 3rd, 19, 12:04 PM Thread Starter
Not on an LS trim Astro van. The intermittent wipers have never worked like this prior to the other day - they always stayed where they were set. I am now seeing that GM did a poor job with electronic components on these vehicles - I had to replace the ABS module, due to poor soldering on the control board. These vans are just poorly built and have zero quality. Not worth owning. The problem is that she loved it when she bought it and does not have the means to get a different vehicle. I am stuck keeping this POS maintained and running until she can no longer drive.
LeoP likes this.
post #8 of 8 (permalink) Old Jan 3rd, 19, 12:14 PM
My Ascender has that. Drove me nutz. Slight rain the wipers would come on. Real rain they wouldn't come on. I unplugged the damm thing, I can turn on stuff when needed, thank you.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
This Thread is more than 382 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
