Power Steering Box Rebuild-1972 - Chevelle Tech
 7Likes
  • 1 Post By 70CHEVELLE396
  • 2 Post By Robinls5
  • 1 Post By Tom Mobley
  • 1 Post By Ethan1
  • 1 Post By Ethan1
post #1 of 10 (permalink) Old Jul 30th, 17, 12:42 PM Thread Starter
Ethan
Couple of questions. Two of the lower bolts snapped off in the housing. They are 7/16-14, correct? I have the Greenfield tap and drill bits for it. Just want to make sure. Finally, I have the case mostly disassembled except for the rack piston and end plug. Problem is, all the ball bearings came out after I removed the worm gear assembly. How can I push the rack piston and end plug out without damaging them? I do have the snap-ring removed as well. What a PITA. Thanks for any help/advice! Ethan
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #2 of 10 (permalink) Old Jul 30th, 17, 1:27 PM
Re: Power Steering Box Rebuild-1972
There is an indepth rebuild thread on here, if you search for it. I read it when I was needing to rebuild mine. I specifically remember the bearing issue your referring to.
HKalin likes this.
70CHEVELLE396 is offline
post #3 of 10 (permalink) Old Jul 30th, 17, 1:44 PM
When you re-install the ball bearings, I believe the ball bearings are different sizes, If I remember????, ( I may be wrong) They go in order of 1-large 1 small 1 large 1 small. Etc.......Mic. the ball bearings to be sure of the size.
I did mine years ago. I do remember when all the ball bearings fell to the cement floor, My Cat almost had a seizure trying to get all of the bouncing and rolling bearings. That was funny.
Ethan1 and jeffss like this.
Robinls5 is offline
post #4 of 10 (permalink) Old Jul 30th, 17, 4:17 PM Thread Starter
Ethan
I found it, but my issue is not installing the ball bearings. It's just removing the rack piston from the case WITHOUT the ball bearings in the piston. I removed the worm gear assembly BEFORE removing the rack piston and end plug.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #5 of 10 (permalink) Old Jul 30th, 17, 7:47 PM
oops. best deal is push the piston out the bottom using the worm gear. Too late for that now.
mount the box in a vise with the piston end pointing down. reach through the hole in the bulkhead where the worm goes through with whatever long skinny thing you have or can find. tap on it or just push the piston out if you can. no biggie. I used a lug wrench for this once. have a folded up old towel on the floor under it, no good having it land on concrete.
Did I mention you'll have to pull the ball return guide gizmo off first? 7/16" socket for that. It won't fit through the bore.
can you post a link to the article or thread where you found the old how-to? Did I write it? or maybe Philip? TIA
Ethan1 likes this.
post #6 of 10 (permalink) Old Jul 30th, 17, 8:34 PM Thread Starter
Ethan
I don't know if this is the thread he was referring to or not, Tom.
https://www.chevelles.com/forums/35-r...5691676-a.html
Thanks for your help, Tom!
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #7 of 10 (permalink) Old Jul 31st, 17, 12:20 AM
I forgot about that thread from michael j even though I posted in it this year. Still a good write-up.
Ethan1 likes this.
post #8 of 10 (permalink) Old Jul 31st, 17, 8:07 AM Thread Starter
Ethan
Got it out! Will post pictures soon. Now, I have to do is remove the last sector shaft seal and bearing. Drill out the old bolts and retap and then it's time for the ultrasonic cleaner.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #9 of 10 (permalink) Old Jul 31st, 17, 4:06 PM Thread Starter
Ethan
A before cleaning and after.
ID:	463018   Click image for larger version
davewho1 likes this.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #10 of 10 (permalink) Old Aug 2nd, 17, 3:36 PM Thread Starter
Ethan
Here is a photo of my homemade spanner wrench. It was two automatic transmission console seal braces, 3-#8-32x3/4" screws, 1 locknut and 2 hexnuts. Cost me $0 and it works GREAT!
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
This Thread is more than 1070 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
