Jeep GC still the best steering box upgrade? - Page 2 - Chevelle Tech
 44Likes
post #16 of 78 (permalink) Old Jun 5th, 17, 6:00 PM
Re: Jeep GC still the best steering box upgrade?
Originally Posted by Paul-ish View Post
Steering box is now on my must buy list since I'm swaping frames right now.
Is the JC still the go to solution? I looked... Can't buy a new one from Dodge anymore so I guess it's an aftermarket or remanufactured i'll have to go with.
Any buying tips?
Or hey, Did anyone do business with( or hear anything about) Lee since they opened back up? I heard a lot of good things about them before they closed down anyway...
Hector Carillo (Carhex) sells the correct #6/7 GM boxes that require no hose adapters and uses the factory rag joint. He retrofits new fast ratio guts in your old box or can supply a core.
https://m.facebook.com/story.php?sto...71461979597583
70GS455 is offline
post #17 of 78 (permalink) Old Jun 5th, 17, 6:12 PM
Cory
BTW - if you send your box to him, a USPS LARGE flat rate box works for under $20
lucifershammer likes this.
dream66 is offline
post #18 of 78 (permalink) Old Jun 5th, 17, 8:33 PM
That is a great option.
Build thread-
Album -
Dan65ss is offline
post #19 of 78 (permalink) Old Jun 5th, 17, 8:58 PM
QUICK RATIO POWER STEERING BOX CHEVELLE SKYLARK CUTLASS GTO CAMARO NOVA IMPALA | eBay
'69 Malibu
Not2Fast is offline
post #20 of 78 (permalink) Old Jun 5th, 17, 9:10 PM
The only issue is what T-bar do they have? The JGC box has the .195 T-bar, so you get better road feel and a little heavier steering. The factory boxes have the .175 T-bar and quite light steering and less road feel.
I had an AGR box with a .210 T-bar. It was very heavy steering, but also defective and wouldn't return to center at all. AGR stood by it even after it was out of warranty and sent me a new one, and they also sent me one with a .204 T-bar instead at no charge. I haven't installed it yet, so I still have a reman stock box with the light .175 T-bar in it.
Once my current to-do list is done, and I have time to mess with it, I'll swap in the AGR box, see if it works right and also check the feel. I'm hopeful, plus the AGR is sunk cost and out of warranty now so if it doesn't work I'll get it rebuilt as it should have plenty of good parts to work with and has the nice billet cap and housing end (I'm not looking for stock appearance.)
So it's not just the fast ratio, it's also the T-bar size and thus road feel.
Paul-ish likes this.
lucifershammer is offline
post #21 of 78 (permalink) Old Jun 6th, 17, 1:54 AM Thread Starter
Paul
I'm in Canada so it will cost way more..
454/T400/9" in a 67 Beaumont
Paul-ish is offline
post #22 of 78 (permalink) Old Jun 6th, 17, 1:56 AM Thread Starter
Paul
This sounds like a good option... I'm not on facebook though... Might have to get the wife to open it for me...
Paul-ish is offline
post #23 of 78 (permalink) Old Jun 6th, 17, 2:47 AM
Leave the wife out in the garage and click on the link I threw up in post #19 above. It's the same guy, guy.
'69 Malibu
Not2Fast is offline
post #24 of 78 (permalink) Old Jun 6th, 17, 8:36 AM
Allen
Originally Posted by Dansk View Post
Look for a seller on ebay called deadjeeps. He sells them for $88 shipped and checks them out. Mine was perfect and probably the best upgrade per dollar I've made.
Thanks for the tip, just ordered one. The auto zone "rebuild" I used leaks badly (top plate to box) but I guess at least I got lucky-ish and it was the quick ratio. Had it on the shelf too long to return.
Blown1932 is offline
post #25 of 78 (permalink) Old Jun 6th, 17, 11:55 PM
Zactly I messaged Carhex on eBay lastnight and he states he uses the oem t-bar.
'69 Malibu
Not2Fast is offline
post #26 of 78 (permalink) Old Jun 7th, 17, 12:31 AM
Lightbulb Re: Jeep GC still the best steering box upgrade?
Another very good option is the Cardone Lifetime Warranty 12.7:1 box for the 1987 Grand National. If you've ever driven a GN, you know how wonderful they drive.
Rex Auftinn is offline
post #27 of 78 (permalink) Old Jun 7th, 17, 1:35 AM Thread Starter
Paul
I wonder if he would put in the Tbar you want... I'm gonna phone him tomorrow.
Not2Fast likes this.
Paul-ish is offline
post #28 of 78 (permalink) Old Jun 7th, 17, 9:54 AM
My Lee 14:1 is 3 turns lock to lock.. The 30lb valve gives excellent road feel.. When I let go of the wheel, it snaps back quick and hard.. My 69 feels like a new Camaro with a rack..
Keep in mind, no steering box is going to change the backward camber or add 5+ degrees of positive caster to the stock suspension..
I paid around 5 bills for my totally new, blueprinted Lee 14:1..
OO52 likes this.
hydro462 is offline
post #29 of 78 (permalink) Old Jun 7th, 17, 11:00 AM
Doug
Has anyone here tried one of Carhex's steering box's?how is the overall feel? I have an original '66 El Camino with 396 and power steering,would I need to change valves on my set up if using a Carhex upgrade?
66 396 is offline
post #30 of 78 (permalink) Old Jun 7th, 17, 11:56 AM
Mark
Here's a local option: https://www.napaonline.com/en/p/NSP88277060
It says it is a 2 1/2-3 turn box, but doesn't give many other details. Taking it back to a store would be better than shipping it back if your not happy.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is online now
This Thread is more than 892 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
