SPC lower control arms question - Chevelle Tech
post #1 of 6 (permalink) Old Jul 5th, 16, 8:22 PM Thread Starter
To "convert" SPC lower control arms for coil-over use, you insert this plate between the shock mount and the arm cup. They say it's to strengthen the mounting point.
It is sandwiched between the shock and the arm, it doesn't bolt to the arm in any way. It's simply a spacer that can't add any strength to anything.
Am I missing something here?
paul bell is offline
post #2 of 6 (permalink) Old Jul 5th, 16, 9:02 PM
Re: SPC lower control arms question
It's a load spreader and re-inforcement. All the load is trying to push the bottom mount out through the bottom of the A-arm. Same bolts that hold the shock also locate the plate. IMO a very simple and effective deal.
We used to make these out of 5/16" plate when we were racing Chevelles on 3/8 and 1/2 mile dirt tracks. Ours were made with a cutting torch, not nearly as pretty.
post #3 of 6 (permalink) Old Jul 5th, 16, 9:48 PM Thread Starter
[QUOTE=Tom Mobley;9016354All the load is trying to push the bottom mount out through the bottom of the A-arm.[/QUOTE]
THAT makes a lot of sense. I wasn't thinking that the shock mount point was ALWAYS being pushed, regardless of suspension movement.
Thanks!
post #4 of 6 (permalink) Old Jul 5th, 16, 10:31 PM Thread Starter
I'm debating between these arms and the CTA42H arms from Global West. GW has the advantage with Delrin bushings, a way nice included sway bar link, included better bump bushing and the shock plate is already thick enough for coil-overs. BUT they're $200 more than the SPC.
post #5 of 6 (permalink) Old Jul 6th, 16, 12:39 PM
If going coilover, I like the Ridetech lower arm better as it eliminates the bolted bottom for a shear bearing for better articulation.
analyte is offline
post #6 of 6 (permalink) Old Jul 7th, 16, 12:12 AM Thread Starter
Very interesting. Adding it to the list. Thanks!
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
This Thread is more than 1321 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
