Energy Suspension Thrust Washers.. - Chevelle Tech
post #1 of 12 (permalink) Old Apr 7th, 05, 11:29 AM Thread Starter
~Scott~
Send a message via AIM to ssal396
Does anyone know the proper locations & the proper part numbers for the thrust washers on a 69 Velle with a 12 bolt posi, & boxed lowers?? I read the instructions 3 times & cant seem to figure it out ..
Any help would be greatly appreciated,
Scott Salerno - 1969 SS 396
TC # 2510
ACES # 6919
How cool is it that my initials are all over my car...
ssal396 is offline
post #2 of 12 (permalink) Old Apr 7th, 05, 1:42 PM
Rich
Re: Energy Suspension Thrust Washers..
What is the part number of the bushing set you purchased?
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is online now
post #3 of 12 (permalink) Old Apr 7th, 05, 1:50 PM
Rich
I'm going to guess you have the set 3-3132. If that's the case and you have boxed lower arms, you will install thrust washer #3087 on both ends of the lower arms and you will also use #3087 on the frame side of the upper arms. On the axle side of the upper arms you will use #3089. The driver's side thrust washer on the axle housing end will need to be trimmed as they show in the diagram.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
post #4 of 12 (permalink) Old Apr 7th, 05, 2:00 PM Thread Starter
~Scott~
Thats the problem, I must have accidentally threw away the box that the kit came in.. I saved all the instructions, but they don't have the part number for the kit on them..
Thanks for the reply,
TC # 2510
ACES # 6919
ssal396 is offline
post #5 of 12 (permalink) Old Apr 7th, 05, 2:18 PM Thread Starter
~Scott~
According to Summits website, it calls for a 3-3132.. The thing that still doesn't make sence is that the instructions say that if you have boxed lowers, to substitute #3087 with 3088, the 3088's don't seem to fit AT ALL.. I'm really thinking od 86'ing all of the darned things ..
I'm just not getting it ..
TC # 2510
ACES # 6919
ssal396 is offline
post #6 of 12 (permalink) Old Apr 7th, 05, 4:37 PM
Rich
Read the instructions again, it says to use #3088 with open arms or if you have a 64-67 A-body. To quote the instructions, "Vehicles with boxed lower control arms use pt #3087 instead of pt #3088."
You have a '69 with boxed arms so #3087s are the ones to use. Running without the thrust washers would be a bad idea.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
post #7 of 12 (permalink) Old Apr 7th, 05, 5:54 PM Thread Starter
~Scott~
Hi Rich, thanks so much for your help.. That was my bad, I typed it wrong, the 3087 thrust washers don't even come close to fitting in there.. The 3088's would go in though..
What would be wrong with not using them?? Didn't these kits come without thrust washers not too long ago I don't ever remember seeing them before..
TC # 2510
ACES # 6919
ssal396 is offline
post #8 of 12 (permalink) Old Apr 7th, 05, 6:13 PM
Rich
I installed a set 4-5 years ago and they have thrust washers. I installed another set this winter on my current project and that kit too had thrust washers.
My cars are '65s and by following their instructions the correct thrust washers were used and fit fine. I don't know how different the 68-72 set up is but I'd think it is quite similar.
When you say they don't fit at all, do you mean they are too thick (don't fit between the arm and the bracket) or aren't big enough around (don't fit over the end of the bushing that protrudes from the arm)? If I remember correctly, the only dimensional difference in the two is their thickness. The ones I used don't fit snug on the end of the bushing shell but are wedged tight between the control arm and the mounting bracket.
Without thrust washers at all, the side loads don't have much surface area to press on on the small end of the bushing. They are intended to fit very snuggly into the mounting bracket on the frame. Greasing them up properly with the grease supplied with the kit helps get them in there and helps the bushings work properly.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
post #9 of 12 (permalink) Old Apr 7th, 05, 6:48 PM Thread Starter
~Scott~
the 3087 is 5/8" thick,but the gap to be filled is only about 1/4"..Like you said it really doesn't fit tight to the bushing, but more importantly, it will not fit between the bushing & the control arm bracket..
TC # 2510
ACES # 6919
ssal396 is offline
post #10 of 12 (permalink) Old Oct 29th, 10, 12:44 AM
Whatley
There was a time, I used to throw away these boxes and I'd find myself nearly popping my eyes out trying to Google. These days before throwing, I note down whatever info is written on the box and take some shots too for back up
handfore is offline
post #11 of 12 (permalink) Old Oct 29th, 10, 2:46 PM
1/4 gap, 5/8 washer. sounds like time to get on the phone to the vendor.
is this on the frame end or the axle end?
post #12 of 12 (permalink) Old Oct 29th, 10, 4:47 PM
George
I couldn't get mine to fit either.....maybe I'll try again this winter, been driving the car without them. Hope that's not a bad thing.
'71 Malibu
355 [email protected]
125 [email protected]
383 Mud Motor- [email protected]
100 shot [email protected]
Geo71 is offline
This Thread is more than 3273 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
pinion thrust washers JERRY66SS 2004 2 Nov 3rd, 04 3:43 PM
Energy Suspension poly bushings?? Lou Merrell Brakes, Suspension & Steering 24 Jul 13th, 04 9:27 PM
energy suspension rear suspension bushings questions Aaron Brakes, Suspension & Steering 2 Jun 28th, 04 11:01 PM
Energy suspension Polyurethane mounts lance-w 2002 9 Sep 25th, 02 6:48 PM
energy suspension body mounts are different than stock hilljack Body Shop 3 Jun 16th, 01 9:34 PM
