All purpose manual brakes - Chevelle Tech
post #1 of 5 (permalink) Old Jan 28th, 16, 7:41 PM Thread Starter
Anyone have a good manual brake master cylinder set up that is a good all around usage? Like daily driving and race track performance?
Aaron is online now
post #2 of 5 (permalink) Old Jan 29th, 16, 4:09 PM
Cliff
Re: All purpose manual brakes
I'm going the manual route on the '64 The pedal ratio has to be right (6 to 1), with the right size master(15/16") and aggressive pads (hawks hps). Not much room for error in the set up. Tobin at Kore3 is a great resource.
Cliff
369 '70 Chevelle
CAM-T
Merlin8188 is offline
post #3 of 5 (permalink) Old Jan 30th, 16, 2:08 AM
R.J.
I have a manual setup that I have been very pleased with both for street and autocross. It is all with older OEM style parts instead of the more common late model Vette/Camaro brake components. Here is a link to my comments about it from when I first put it together.
https://www.chevelles.com/forums/56-p...w-hawk-hp.html
Here is the highlights from that post:
... it is a fairly low tech, low buck 4-wheel disc system. The fronts are C3 Corvette rotors (12”x1.25”) with GM JD7 Suburban calipers with 3 5/32 pistons. And the rears are ’81 Trans Am rear rotors (11”x.810”) with GM ‘Metric’ calipers (G-body front calipers) with 2 ½” pistons. The plumbing is all stainless steel hard lines and braided stainless steel hoses. The master cylinder is a ’71 Corvette power brake unit with a 1 1/8” bore. Also I have a manual brake bias valve installed in the rear line.
R.J.
1972 Chevelle
The Ice Blog:
airrj is offline
post #4 of 5 (permalink) Old Jan 30th, 16, 5:03 AM
RJ, correct me if I am wrong, but this setup is the CBB, and uses the B-body Tall spindle, correct? But the calipers bolt directly to the tall spindles... And those hubs I got from you (now where did I put those hubs?)...
And despite the "power" master, it was used as a manual, with the bigger bore due to the larger caliper pistons...
I used the manual Corvette master with the Kore3 C5 conversion (still had rear drums), felt great, stopped well, some windy mountain roads in the Sierras but I hadn't raced the car or pushed really hard...
TC #1366
Sold
Sold
1966_L78 is offline
post #5 of 5 (permalink) Old Jan 31st, 16, 11:19 AM
R.J.
Yes Tony you are correct. It is the B-body spindle CBB swap. I knew there was something missing on my post. Amazing how much is available now over 2003 when I put mine together. Not a fancy looking setup, but for the cost of what I have into it the results are very good.
R.J.
1972 Chevelle
The Ice Blog:
airrj is offline
This Thread is more than 1456 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
