How to preserve uninstalled Master Cylinder - Chevelle Tech
post #1 of 5 (permalink) Old Aug 30th, 15, 5:07 PM Thread Starter
I am going to install a m.c. rebuild kit[from napa] in an original 1970 5470409 m.c..I will also get the m.c. lid plated.The bore is smooth with no pitting.Instead of honing the bore[more expense]I will lightly sand it.At least that is my plan?This will not be going back onto the car.How do I preserve the bore,resevoirs,and exterior of the m.c. while stored?Thanks
Scott 1970 SS 396 is offline
post #2 of 5 (permalink) Old Aug 30th, 15, 5:50 PM
Re: How to preserve uninstalled Master Cylinder
Cosmolene,
1953 Chevy Bel Air 4 door.
1968 Chevy C20 CST Longbed.
1967 Malibu 396 Powerglide.
Cal Malibu is offline
post #3 of 5 (permalink) Old Aug 30th, 15, 8:15 PM
z27
alex
Scott sanding is no good it has to be honed with very fine stones. Sanding will not be even for the circumference nor will the pressure exerted be the same as a hone all the way around. Don't rebuild it till your ready to use it . Cosmaline will preserve it so will spray grease and then a zip lock bag. Alex
z27 is offline
post #4 of 5 (permalink) Old Aug 30th, 15, 10:05 PM Thread Starter
Thanks guys.Good thought about not putting the kit in it untill needed,Alex.I have never honed anything before,try to do it myself or machine shop?Where would I buy the Cosmoline?Thanks for your thoughts.
post #5 of 5 (permalink) Old Aug 30th, 15, 11:28 PM
You can buy a wheel cylinder hone at any parts store to hone your mc. Jim
Jim Mac is offline
This Thread is more than 1734 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
