Time for front suspension upgrade - Chevelle Tech
post #1 of 6 (permalink) Old Aug 29th, 15, 2:59 PM Thread Starter
I have a 1968 Chevelle that is in bad need of an upgrade.
I have owned it sense 1990 and it has some mismatched front end parts.
I think it has stock front upper and lower control arms but the spindles were changed to
add disc drakes. When I went to change the front rotors I found that 68-72 did not match.
after looking through boxes of them I found 73 were a match. then I knew why things were
not quite right. I have drove it like this for years but only went for short rides to car shows.
I would like to start over and do it right.
I do run 15" skinny rims and tires on the front, I like the drag car look and it sees some time there.
How do I tell if the a arms are correct, calipers? I would say the spindles are wrong.
not looking for a corner cutter but would like it to drive like a modern car
I was also going to do the jeep steering box change.
Thinking about tubular arms and all if I replace them
Ideas?
WEEKEND WARRIOR is offline
post #2 of 6 (permalink) Old Aug 29th, 15, 8:08 PM
mark
Re: Time for front suspension upgrade
If correct for 68 is important, check out RockAuto for replacement parts. I do believe the 68 had 4 piston calipers. 69 and up had single piston.
I like the UMI arms. I did the rear of my 69 with all UMI.
If I can find a really light weight set for the front, I will do that next (just straight line for me also} All the tubular front arms are actually heavier than the stockers. I understand they are much stronger, but I would like them to be very light for drag racing applications.
1969 Chevelle
412 small block
M-20 4spd
4:10 12 bolt
Sold, went to Sweden
1957 Thundarbird Gasser
Aluminum Shafiroff 582
Richmond 6spd
4:33 59 Olds rear
Dads old race car
He bought it in 1967
1967 Camaro
355 small block
M21 4spd
4:88 12 bolt spool
40yr old drag car
barn find in south PHX AZ
marks412 is offline
post #3 of 6 (permalink) Old Aug 30th, 15, 8:03 PM Thread Starter
Not looking for period correct
I didn't know the tubular A arms were heaver
I know the 68 has 4 pistons, not worried about that either
just want it to drive better and work with my rim/tires
I do believe there are some "drag race only" ones that are light weight
But I do want to do more street driving
I may just order stock replacement spindles, hoping the other stuff is correct
but still will drive like a 68-72 car, still better then what I have
I do run 90/10 shocks and know it will never steer perfect
but I like the weight transfer I get from them
post #4 of 6 (permalink) Old Sep 6th, 15, 3:15 PM Thread Starter
Those that have did the "Jeep upgrade Box" with all else stock
Does is now drive like a modern car?
not saying a Camaro, just like an up to date car-truck
just that mine has never been correct sense I owned it
I realize it's just a ratio change
just hope stock suspension with the "box" change doesn't leave me disappointed.
then will have to start over....
Thoughts?
post #5 of 6 (permalink) Old Sep 6th, 15, 7:03 PM
My 71 is mostly stock up front. Jeep box, SBC w/air springs, 1.125 sway bar, 90/10 shocks, poly bushings. Handles decent with a BBC and the Jeep box got rid of the vague steering feel the stock PS box had.
dell72 is offline
post #6 of 6 (permalink) Old Sep 7th, 15, 12:02 AM
blm
If you want to educate yourself on suspensions I would recommend you pick up the following book. A lot of good information in it.
blm is online now
This Thread is more than 1627 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
