Jeep GC steering box / Lee Mfg. fittings, HELP! - Chevelle Tech
post #1 of 14 (permalink) Old Aug 22nd, 15, 8:56 PM Thread Starter
So i'm in the middle of this conversion (car torn apart) and now realize the "bolt in" pump i have is not so bolt in afterall. So now i'm desperate for Lee Mfg's conversion fittings to make my flare nut lines bolt into the Jeep box. Well, both phone lines listed on the website are disconnected and an AT&T message makes it sound like they have gone out of biz. No place to order from the website. I have sent an email to the address listed on the website but not expecting any reply atleast until Monday.....if at all. The website shows to have been updated this year.
Does anyone know anything about the company.....have they gone out of biz? If so, any idea where i can get the flare nut to o-ring conversion fittings?
shannon is offline
post #2 of 14 (permalink) Old Aug 22nd, 15, 9:04 PM
Re: Jeep GC steering box / Lee Mfg. fittings, HELP!
A better way to do it is to skip those goofy adapters and do it right. Use a pressure hose from an 81 Camaro, an O-ring fitting for the back of the pump, and grab a return line O-ring fitting to go in the box for the return hose.
Oh, and Lee has gone out of business, apparently.
72 Chevelle SS conv
72ragtop is offline
post #3 of 14 (permalink) Old Aug 22nd, 15, 9:15 PM Thread Starter
Doing it the better way, and doing it right is exactly what i was trying to do.....with a new / reman'd 85 Camaro pump which Hot Rod magazine claimed was a bolt in. Long story short, the 85 pump is not a bolt in....the "clocking" of the pump in the reservoir is out of whack. What i have resorted to at this point is removing the o-ring fitting from the 85 camaro pump and putting it in my 71 Chevelle pump. I think this will solve the issue, but i won't know until i have it all together and running. So if it winds up not working i would like to know where i can find the fittings.
shannon is offline
post #4 of 14 (permalink) Old Aug 22nd, 15, 9:28 PM
Phil
These look/sound like the adapters... https://www.borgeson.com/xcart/produ...productid=1759
71 Chevelle SS
zz502 (Straub Cam, RPM Airgap, ProSystems Carb, MSD, etc.)
Rossler TH400
Built 12 bolt 4:11
Slick71ss is offline
post #5 of 14 (permalink) Old Aug 22nd, 15, 9:45 PM Thread Starter
Thank you very much Slick71. I did come across something similar to these while searching the web earlier today. Speedway had them so i called but the person i talked to didnt have much clue what i was talking about and wanted to know thread sizes and pitches, etc......which i myself was clueless about. I think what i have done (swapping the o-ring fitting into my pump will work. But if it doesn't i now am relieved to know this place will probably be able to help.
shannon is offline
post #6 of 14 (permalink) Old Aug 22nd, 15, 10:50 PM
Do you have the part numbers for these?
TC #0672
1972 SS 454 M22
"W " Code Midnight Bronze
Bandit1978 is offline
post #7 of 14 (permalink) Old Aug 23rd, 15, 12:12 AM
blm
Do a search on Ebay under the following heading "55 56 57 Chevy 605 steering o ring adapters" they are a direct thread into the JGC steering box and your lines will thread right into the adapters. UUsed them on my conversion to the.JGC box. Sold. by Classic Performance for $19.00. Their part # 605SOL*postal.
blm is offline
post #8 of 14 (permalink) Old Aug 23rd, 15, 7:35 AM Thread Starter
Thank you for that tip as well.
shannon is offline
post #9 of 14 (permalink) Old Aug 23rd, 15, 9:26 AM
Would this be better than the Lee's?
TC #0672
1972 SS 454 M22
post #10 of 14 (permalink) Old Aug 23rd, 15, 12:48 PM Thread Starter
I did get a reply email from Lee Mfg. Unfortunately Mr. Lee has retired and is not currently giving any referrals. Bummer.
shannon is offline
post #11 of 14 (permalink) Old Aug 23rd, 15, 2:51 PM
blm
Shannon:.
I am not familiar with the Lee's fittings but I believe they are press in. If that is the case then I would believe the Classic Performance are superior as one can just unthread them if they have the desire or need to and as many times as necessary. Here is the link.
http://www.ebay.com/itm/55-56-57-CHE...-/261142836721
blm is offline
post #12 of 14 (permalink) Old Aug 23rd, 15, 5:48 PM
Derrick
^^^this.... do this^^^
the pressure line is like $15 at any parts store in the country... swap out the fitting on the back of the pump with one from any 80's vehicle with a Saginaw pump... hit the junkyard to get a return line off a steering box off an 80's something with a Saginaw steering box for a few bucks and it's done.. no stupid adapters, no threading SAE threads into metric threads- just a good solid oem engineered setup that works and doesn't leak..
i should get the parts to sell them as a kit.. i'm sure someone would pay me $200 for $20 worth of parts...
-Hank Hill
novaderrik is offline
post #13 of 14 (permalink) Old Aug 23rd, 15, 6:06 PM
Phil
Shannon:.
Those adapters do look like a better solution than the press in ones. Thanks for the link.
71 Chevelle SS
Rossler TH400
Built 12 bolt 4:11
post #14 of 14 (permalink) Old Aug 23rd, 15, 6:30 PM Thread Starter
a perfect example of one of the many reasons i left this site many years ago. Please, Please, Please read the threads before replying. For the third time....That's what my plans were....I have all the parts the Hot Rod mag article recommended (Trusting anything David Freiberger has a hand in was my first mistake)......the "bolt in" 85 Camaro pump turned out to not be bolt in. SO YES, i have removed the o-ring fitting from the 85 camaro pump and installed it in my 72 pump. YES....i do have all the new o-ring pressure lines, etc. Since i have never "tinkered" with re-engineering a power steering pump my concern was that the fitting swap i did may not work....And i wanted an option for the fittings in case that did not work.
Please Guys, Please read threads entirely before posting so you don't wind up looking like a "know it all"!!
To those who posted links and helpful suggestions for alternatives to the Lee Mfg. fittings, "Thank You".
shannon is offline
Closed Thread
This Thread is more than 1738 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
