10 bolt to 12 bolt - Chevelle Tech
post #1 of 11 (permalink) Old Sep 27th, 14, 8:35 PM Thread Starter
10 bolt to 12 bolt
does anyone know if the drum backing plates and drums themselves are the same on a 10 bolt and 12 bolt.I recently bought a 12 bolt out of a 1968 chevelle to put in my 1969 chevelle.The 12 bolt didn't come with the brake backing plates and hardware so was just wondering if I can switch mine from my 10 bolt to the 12 bolt..thanks
joes66 is offline
post #2 of 11 (permalink) Old Sep 27th, 14, 9:29 PM
Re: 10 bolt to 12 bolt
I recently a 10 bolt to 12 bolt swap on my Chevelle and used my 10 bolt brakes on the new 12 bolt. Good luck with the swap, the brakes are the most work in my opinion. Don't forget that the 12 bolt takes a special upper control arm on the passenger side.
1971 Malibu Sport Coupe 350 (Lunati Voodoo 20120711 cam) / 350 / 3.31 12 bolt posi. 2-1/2 inch torque tech exhaust with walker turbo mufflers.
I love a science project that involves an auto.......
71MalibuSC is offline
post #3 of 11 (permalink) Old Sep 27th, 14, 9:52 PM Thread Starter
thanks for the reply,I was unaware of the special control arm..What am I looking for in the control arms.So I can buy one before the swap
joes66 is offline
post #4 of 11 (permalink) Old Sep 27th, 14, 10:34 PM
AKA Zombietroll
When I swapped out my 10 bolt for a 12 in my 71 the uppers wouldn't fit. Not a big deal just grind some metal of the arm for clearance and you're good to go. You'll see what I'm talking about.
zombie1969 is offline
post #5 of 11 (permalink) Old Sep 28th, 14, 3:46 PM
oem
Richard
I swapped my 69 10 bolt for a 12 bolt and never ran into any problems, everything bolted in just fine.
oem is offline
post #6 of 11 (permalink) Old Sep 28th, 14, 4:20 PM
jerry
If you're gonna grind down your trailing arm, be sure and weld a 1/2" flat washer to the outside. I wouldnt' trust the arm after taking away that extra metal. The chevy engineers didn't either, as they spotted on a reinforcement.
cheveslakr is offline
post #7 of 11 (permalink) Old Sep 28th, 14, 5:33 PM
Banned
Anthony
I`ve done a few 10 bolt to 12 bolt swaps and never had a issue reusing the control arms.
sschevellefan is offline
post #8 of 11 (permalink) Old Sep 28th, 14, 6:45 PM
Where is there a problem with the control arms?
I just replaced my 10 with a 12 bolt in a '69 and didn't notice any issues.
Is it on certain years?
danbo is offline
post #9 of 11 (permalink) Old Oct 1st, 14, 12:06 AM
Kent & Kam
That`s new to me too ??? expand please....
1971 Chevelle Father/Son Build
Our Link
Team Chevelle #5544 North Texas Camaro Club
71 454 is offline
post #10 of 11 (permalink) Old Oct 1st, 14, 12:26 AM
The 12 bolt center section is larger due to the larger ring gear. The unmodified upper trailing arm on the driver side will hit the center of the housing. Factory upper trailing arms on the driver side had some material ground away and a reinforcement tab welded on.
The brakes are identical between the 10 & 12 bolt rears.
BlueSS454 is offline
post #11 of 11 (permalink) Old Oct 1st, 14, 3:06 PM
You MAY be able to get the arms to bolt up, but it will probably be tough getting the bushing and arm holes to line up ( might need to tap or "screw" the bolt through the hole, etc)...
Here's a website with pictures explaining the upper control arm differences...
http://www.leverfamilysite.com/Rear_...ifferences.htm
Although the pictures show 68-72 arms, the same clearance issue exists with all Chevelle 12-bolts and 10-bolt arms...
The brakes should swap completely, even the brake lines should work... Just need to pop the axles out and 4 bolts to remove each backing plate. I have even removed the brakes/backing from the axle while still in the car, without disconnecting the brake lines/hoses (no one around to help bleed the brakes)... Swapped rearends and bolted the brakes back up...
TC #1366
Sold
Sold
1966_L78 is offline
This Thread is more than 1871 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
