71 chevelle proportioning valve HELP! - Chevelle Tech
post #1 of 3 (permalink) Old Jan 30th, 13, 9:44 PM Thread Starter
Hi guys,
Been sniffing around this awesome site for a while and have my first question! I purchased a pol front brake kit as per bellow link! Now on the 71 the proportioning valve is on the chassis, or is it a distribution block? Is the valve in this kit a direct replacement? I am confused over distribution blocks and proportioning valves! Did the 71 have both in one valve?
http://www.performanceonline.com/196...ion-Kit-17717/
Sorry for the newby questions!
Regards
Lisnm8 is offline
post #2 of 3 (permalink) Old Jan 31st, 13, 7:46 AM
Re: 71 chevelle proportioning valve HELP!
Correct, beginning in `71 the separate hold off valve up by the master cylinder was eliminated.
_____________________________________________
'65 Buick Skylark,
406 sbc, 10.07 comp, ported Trick Flow 195 heads, RPM Air gap, Holley 3310, Straub HR .547/.516 233/243, Hedmans, 200-4R, 10" 3,200, 4.10 12 bolt.....and factory a/c
65 Skylark is offline
post #3 of 3 (permalink) Old Feb 3rd, 13, 9:24 PM
Yes on a 71 it is called a combination valve because the proportioning valve and distribution block are one item.
1969 SS396 Convertible
Bob Tiley is offline
This Thread is more than 2506 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
