1970 SS Front Sway Bar - Chevelle Tech
post #1 of 6 (permalink) Old Mar 10th, 12, 12:40 PM Thread Starter
Rich
What is the stock diameter of the front sway bar for a '70 SS without RPO F41? Mine measures 15/16". Is that correct? Also, what was the stock size of the sway bar on a small block?
Big White is offline
post #2 of 6 (permalink) Old Mar 11th, 12, 12:41 PM
& Administrator
Re: 1970 SS Front Sway Bar
Chevy parts catalog shows:
401194 -1" exc. Spec. Perf.Susp.
402544 - 1.250" w/Spec. Perf.Susp.
Mike is offline
post #3 of 6 (permalink) Old Mar 11th, 12, 12:59 PM Thread Starter
Rich
OK, so you move my thread and then throw a couple parts catalog numbers at me with no explanation of where they are used. How about answering the question:
What's the diameter of a stock '70 non-F41 SS front sway bar and what's the diameter of a stock '70 small block front sway bar?
post #4 of 6 (permalink) Old Mar 11th, 12, 1:09 PM
& Administrator
Yeah ,they are both described as to there usage.
I didn't post the year used as I thought you asked about a 70.
Shows no difference from SBC to BBC in the parts catalog.
Stock '70 non-F41 SS front sway bar is GM p/n 401194 -1" exc. Spec. Perf.Susp.
As posted
Only .875" shaft showing is for 69 Chevelle and 70-72 MC
Mike is offline
post #5 of 6 (permalink) Old Mar 12th, 12, 8:39 AM
Anakin
Way to go off on the guy and be a jerk to somebody who DID answer the question you asked.
lrdvdr41 is offline
post #6 of 6 (permalink) Old May 2nd, 12, 6:56 PM
Murph
I think the actual diameter of the 1" sway bar is 15/16".
Sent from my Autoguide iPad app
Murphs69 is offline
This Thread is more than 2948 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
