Jeep box upgrade-PICS-and then some... - Page 52 - Chevelle Tech
 42Likes
post #766 of 791 (permalink) Old Feb 15th, 19, 8:59 PM
Jason
Re: Jeep box upgrade-PICS-and then some...
I am currently doing this swap. Got a box out of a 97 grand Cherokee at Pull-a-part. Just rebuilt it and the PS pump. Can I use ATF or do I need to use PS fluid for the box?
Zavero is offline
post #767 of 791 (permalink) Old Feb 15th, 19, 9:22 PM
Since they are both about the same cost, I'd use power steering fluid. However, I do admit that I have used ATF before with apparently no ill effects.
B52bombardier1 is offline
post #768 of 791 (permalink) Old Feb 16th, 19, 12:25 PM
Power steering fluid..
TC #0672
1972 SS 454 M22
"W " Code Midnight Bronze
Bandit1978 is offline
post #769 of 791 (permalink) Old Mar 29th, 19, 8:35 AM
Beth
Here's a great article by Jeff Smith on this topic.
In the comments section, there are updated parts listed to adapt these steering boxes :
https://www.onallcylinders.com/2014/...arly-chevelle/
nashville beth is offline
post #770 of 791 (permalink) Old Oct 31st, 19, 3:23 PM
Yes, dragging this thread to the top again.
So I have spent a few days reading every-single-post in this thread and have come up with a parts list. Though it does still sound like a crap shoot to get one from AutoZone, Advance Auto or Rock Auto, or even a junkyard (these JGC are over 20 years old now). Best bet may be to send the original to https://benchworksteering.com/ and have them build it to your specs (12.7:1 radio with 2.02 T-Bar)?. The couple of people that used them didn't post $$$ though.
One burning question I had while reading through this that was never answered was why were so many people using the flare to metric adapters or worrying about the right hoses when you can (I think?) easily make your own with -6 AN fittings?! There were only TWO posts by those that did exactly that (one with nice photos). Here are the parts I found that should work (but have not confirmed):
EAR-961955ERL -6 AN to 16mm x 1.5 Male
EAR-961956ERL -6 AN to 18mm x 1.5 Male
Then use 3/8" PTFE hose (it can handle the pressure) and female PTFE compatible AN fittings on the hose. Looks great and can customize exactly how to route them. That's my plan...
But before I jump in though, I want to investigate the hydroboost setup (get pump from '80s K10 truck that has 2 returns), and a collapsible steering column for my '66.
Gunn317 is offline
post #771 of 791 (permalink) Old Oct 31st, 19, 4:40 PM
CARHEX (Hector Carillo) is now selling rebuilt Jeep GC boxes
70GS455 is offline
post #772 of 791 (permalink) Old Oct 31st, 19, 7:02 PM
I would consider the collapsible column as well at the time. And I didn't use any adapters for fittings either. I converted to a more modern pump at the same time and used a Camaro pressure hose with O-rings on both ends, and I used the Jeep fitting for the return line.
The difference between stock power steering and the JGC box is more different than the JCG box to anything else. The stock on mine was over 4 turns lock to lock, now just over 3, and while much firmer feel, it is not hard at all. The factory power steering was WAY overboosted on mine, a baby's pinkie could steer it, zero effort, zero feel, and had to hand over hand making turns.
Gunn317 likes this.
Pioneer4x4 is offline
post #773 of 791 (permalink) Old Oct 31st, 19, 7:26 PM
dit toe
'69 Malibu
Not2Fast is online now
post #774 of 791 (permalink) Old Oct 31st, 19, 7:46 PM
Troy
I did (doing) my 66 with PTFE lines.
I used a new Borgeson 12 to 1 box and collapsible column also from Borgeson. Also going with Hydroboost.
You can see some info in my build thread, staring on post 21.
https://www.chevelles.com/forums/10329833-post21.html
Sent from my SM-T720 using Tapatalk
Gunn317 likes this.
66 CHEVELLE
senna is offline
post #775 of 791 (permalink) Old Oct 31st, 19, 10:49 PM
How do you plan to connect the hot-rod hose to the pump?
Schurkey is offline
post #776 of 791 (permalink) Old Oct 31st, 19, 10:53 PM
Troy
What is a hot-rod hose?
Gunn317 likes this.
66 CHEVELLE
senna is offline
post #777 of 791 (permalink) Old Nov 1st, 19, 1:45 PM
PTFE lines.
Pretty much any "stainless steel braid over [rubber liner] [Teflon/PTFE]" hose and fittings that are sold as "AN" even though that's false advertising.
Schurkey is offline
post #778 of 791 (permalink) Old Dec 8th, 19, 10:58 PM
Dennis
[QUOTE]
Originally Posted by sglide View Post
Recently, I read an article on the Jeep swap-over and it mentioned that you have to change the pressure valve in the stock GM PS pump to the higher pressure valve. However, I don't remember ever reading that in any of the forums. Can someone shine a light on this for me? When you swap over to the Jeep box and you use the original PS pump, did anyone change the pressure valve in the pump to the higher pressure valve? Or, did the stock pump work OK with just the hose change-over? Thanks!
The pressure valve is set to 950psi in pre-1970 cars, 1450psi in '70 and up, according to Jim Shea. If you've got a '70 or later car, you're fine, if not, you've got to take the pressure valve from the donor car, which is the fitting the pressure hose threads into on the back of the pump - it just unscrews. As an added bonus, a later pressure valve will have the later O-ring seal, but the pump end will be the same and will thread into your existing pump.
- Eric
I found this WAY back in the beginning of this 52 page post and it got me thinking.
The PS pump on my LFX V6 is rated for 1.7-2.1 GPM @ 1633-1754 PSI. Same as an LS mounted pump.
Will this higher pressure make the steering feel “over assisted”? I already swapped to a 12:1 Saginaw 800 box and while it turns quicker it still feels overly assisted. I did a similar Saginaw 800 swap in a 67 and it felt way stiffer.
66 Chevelle hardtop - LFX 3.6 liter 4 Cam V6/6L50 6 speed auto trans, 3.07 10 bolt, full Hotchkis suspension, Wilwood 4 wheel discs, white with red interior, cowl hood.
67_LS1 is offline
post #779 of 791 (permalink) Old Dec 8th, 19, 11:59 PM
Gear ratio, and torsion bar diameter (stiffness) inside the steering gear, and hydraulic pressure from the pump, all play a part.
The Jeep GC box does not have the biggest-diameter torsion bar, only the second-biggest (as I remember it). Far stiffer than the original, though.
Schurkey is offline
post #780 of 791 (permalink) Old Feb 19th, 20, 11:05 PM
Wes
Originally Posted by 1967 chevelle malibu View Post
My box was rebuilt by Benchworks in Scottsdale AZ.Benchwork Steering Systems
Would you mind telling what the cost was for Benchworks to rebuild your box?
Thanks Wes
RR24 is offline
