Jeep box upgrade-PICS-and then some... - Page 5 - Chevelle Tech
 42Likes
post #61 of 791 (permalink) Old Jan 6th, 12, 9:09 PM
Pat
Re: Jeep box upgrade-PICS-and then some...
I have to add, on a 1967 the drivers side bumper brackets need to be loosened so they can be moved in order to get the top steering gear bolt out using a socket. At least that was the case with mine
1967 Chevelle SS 325HP M20
Yesterdays Chevelles & ElCaminos Member
SS396-67 is offline
post #62 of 791 (permalink) Old Jan 25th, 12, 9:16 PM
Jason
So is the Lares 1353 correct? What ratio?
LSxChevelle is offline
post #63 of 791 (permalink) Old Feb 5th, 12, 1:19 PM
Hey Guys, I wanted to jump in and let you know what I did. When I got my salvage yard JGC box I also took the lower half of the steering column shaft with u joints on each end instead of a rag joint and a slide together section in the middle . My 66 EC didn't have a collapsible column. So I removed my original steering shaft and cut just over 15" from the bottom to splice in the collapsible shaft. The JGC u joint at the top has a double D type u joint and the EC shaft has a round shaft. I slipped a piece of 3/4" ID 1" OD 1/8" wall tubing over the EC's 3/4" round shaft and tack welded on to make up the difference. Then being able to shape it to the double D. After I buffed down the new metal to a double D shape it bolted together perfectly. I took the opportunity to change the upper and lower column bearings. This turned out really well. I hope this isn't confusing.
post #64 of 791 (permalink) Old Feb 6th, 12, 7:48 PM
im looking to do this upgrade, but at the same time im doing an IDIDIT tilt column.... but it looks like ill need an installation kit to attached everything together. does anyone know which kit i need... not sure about the spline count of the JGC box
thanks
steve
ericburnes likes this.
SVC707 is offline
post #65 of 791 (permalink) Old Feb 6th, 12, 10:36 PM
Jon
I saw where some one posted about AN fittings and I didn't see an answer. Will this work with a braided hose? Pump and gear sides?
**Built not Bought**
1972 Chevelle, UMI Suspension, Kore3 Brakes, Soon to be 5.3L Turbo/T56
1fast72 is offline
post #66 of 791 (permalink) Old Feb 9th, 12, 9:02 AM
Can this swap be done using the lees drop in fitting adapters and the stock hoses on my pump in a 72 small block
smokenjoep01 is offline
post #67 of 791 (permalink) Old Feb 9th, 12, 11:47 AM
Pat
Smokenjoe,
Yes, I just installed gearbox with the adapters and used my old hoses on my '67 and it works perfectly, should be the same for a small block. Now it is 3 turns lock to lock and provides much more road feel, plus it is quicker. All in all, an excellent upgrade
SS396-67 is offline
post #68 of 791 (permalink) Old Feb 9th, 12, 12:16 PM
Thanks for the fast reply. I was just double checking. I did mine last night and couldnt find a hppy route for the hoses. The High pressure seems fine, but the metal end with the nut on the low pressure must have been bent at some point and needs some massaging.
post #69 of 791 (permalink) Old Feb 19th, 12, 1:06 PM
Tim
Wanting to do the Jeep / Chevelle steering box swapon my 69 Camino .The local salvage yard dosent have a Jeep G C , Will order from Napa I guess or look on E bay. Then a rag joint and ,Lees for hose adapters . Any other advice would be appreciated.
Thanks Tim
TimNY is offline
post #70 of 791 (permalink) Old Feb 19th, 12, 11:48 PM
Phil
Cheapest remanufactured Jeep Grand Cherokee box I found was the Lares 1353 from Rockauto. Also got the Lares 200 rag joint from Rockauto and the Lee adapters.
Lares 1353 & Lares 200 shipped... $ 133.34
Lee adapters & install tool shipped... $20.35
$153.69 total spent on the upgrade, and I didn't have to bother going to a junkyard or turning in a core.
71 Chevelle SS
zz502 (Straub Cam, RPM Airgap, ProSystems Carb, MSD, etc.)
Rossler TH400
Built 12 bolt 4:11
Slick71ss is offline
post #71 of 791 (permalink) Old Feb 22nd, 12, 3:31 PM
Just wanted to double check!!!
1) will stock hoses from a 67 SS fit the JGC boxes threads if I use Lee's fittings or are the threads on the gear metric???
2) will stock hoses from a 67 SS fit a GM 1450 psi stock pressure valve in the pump or are the threads metric???
3) is the JGC steering gear a 30 or 36 spline shaft???
Want to do the conversion but want to make sure I have all that is needed to complete it in one afternoon so if I am missing anything, please let me know!!!
Thanx
Hope yous don't mind me braking into this thread!!!
John 67 SS is offline
post #72 of 791 (permalink) Old Feb 23rd, 12, 7:59 AM
Verle
I believe the answers to your questions are all here:
https://www.chevelles.com/forums/showthread.php?t=334534
Verle
Tulsa, Ok
Verle is offline
post #73 of 791 (permalink) Old Mar 12th, 12, 2:58 PM
Jason
i just put my jeep box, im also putting a hydro boost in. I want to use AN fittings. My question is can i must use the earls adaptors. what is the reason for the LEE press in pieces.. what rag joint do i use from the local parts store.
72_elcamio_man is offline
post #74 of 791 (permalink) Old Mar 12th, 12, 10:40 PM
You ned to use adapters if you want to use your original American flare hoses with the Jeep Metric O-ring receptacles.
The rag joint should be a Lares 202 (about $30 at Advance Auto) or a Dorman 31011 (about $75), if I recall. If you use the Lares, make sure you've got enough clearance to the casting for your socket to go completely over the 12-sided pinch bolt nut - if it's only part way on, you could think you tightened it when you didn't, with "exciting" results on the road.
- Eric
MDchanic is offline
post #75 of 791 (permalink) Old Mar 17th, 12, 6:20 PM
Jack
I have got an installation question. I have my new Steering Box and Rag Joint. On the new Box I rotated the input shaft both directions to the stops and then back to center, then I installed the new Rag Joint. Now, if I have the wheels straight, and the steering wheel centered, should the column match up to the new Rag Joint? If it doesn't, is this something that can be corrected during an alignment? I plan to mark the Pitman Arm location on the old box and place it in the same place on the new Box before installation. Is this correct? Since I am going to also replace the Tie Rods, Center Link and Idler Arm at the same time as the Box replacement, am I correct that I should replace the Box FIRST?
jmelong is offline
