Jeep box upgrade-PICS-and then some... - Page 39 - Chevelle Tech
 42Likes
post #571 of 783 (permalink) Old Jun 23rd, 16, 1:04 AM
So it just had a quick question about doing the jeep steering gear box swap. I'm about half way through mine and I noticed that the oem gearbox has a little nipple that sticks out the end of the gear box pointing towards the steering shaft and the new jeep box does not have this. Is this an issue and if so how do I go about fixing it?
Andys72 is offline
post #572 of 783 (permalink) Old Jun 23rd, 16, 1:07 AM
This is the oem box
Andys72 is offline
post #573 of 783 (permalink) Old Jun 23rd, 16, 1:45 AM
Re: Jeep box upgrade-PICS-and then some...
Same with me. Use the correct rag joint and you won't have any problems.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #574 of 783 (permalink) Old Jun 23rd, 16, 7:37 AM
The jeep rag joint for the jeep box?
Andys72 is offline
post #575 of 783 (permalink) Old Jun 23rd, 16, 1:28 PM
Wayne
My jeep steering box doesn't have that nipple. I bought two out of a junk yard and neither had the nipple.
Ga69abody is offline
post #576 of 783 (permalink) Old Jun 23rd, 16, 4:16 PM
It's the 72 chevelle box that has the nipple
Andys72 is offline
post #577 of 783 (permalink) Old Jun 28th, 16, 11:35 AM
Craig
This thread appears to be the "reference" thread for the JGC steering gear update, so I thought I'd add some new information I received this morning from BBB industries. BBB industries is the company that rebuilds many of the steering gears sold in the US. They recently purchased ATSCO, so they provide the gears for Autozone, ACDelco and many others. I simply asked them if they sold a steering gear that provided the exact same specifications as the JGC gear (I.e. 12.7 ratio, 87 degrees (43 degrees, 30 minutes each direction from center) of pitman arm travel and 3.1 turns lock to lock on the input shaft. Their response:
"No sir we do not offer an exact replacement for your current gear"
This confirms my measurements obtained from two Autozone gears and two ACDelco 36g0070 gears. All were 14 to 1 "generic" gears that were assembled to fit many applications. This also seems to contradict the popular belief that these companies just throw together the remanufactured gears with whatever parts happen to be returned as cores. I believe they know exactly what they are doing and they have decided that a 14 to 1 box is the best generic match for their business. This also convinces me that it won't be possible to buy a remanufactured 12.7 JGC gear, so the only option will be a used gear obtained from a JGC, or one of the more expensive aftermarket gears from AGR, Turn One, or the others. Does anybody have any measured data obtained from remanufactured gears that shows otherwise? I'd sure like to find a "correct" JGC gear, but don't believe that it's currently an option. Please let me know, as I'm hoping somebody will prove me wrong.
Craig
BTW - I sent the same inquiry to Lares, so I'll update my response when and if Lares responds
craigs66 is offline
post #578 of 783 (permalink) Old Jun 28th, 16, 1:31 PM
I heard back from Lares within 5 days when I contacted them in March. I didn't get all the details I wanted via email so I called and spoke with someone fairly easily.
-Joe
Team Chevelle #2680
'69 Malibu Convertible
joeyv69ragtop is offline
post #579 of 783 (permalink) Old Aug 29th, 16, 11:11 AM
Todd
Is there a difference between the 66 chevelle pitman arm on a manual vs power steering box. Is the spline shaft bigger on a chevelle power steering box.
I purchased a JGC 7525 rebuilt box and my pitman arm from my old chevelle steering box seems to small. I seem to remember there was two different ones but I cannot remember if it was power vs manual or hardtop vs convertible.
Can anyone shed some light on this subject?
I am doing an LS conversion and wanted to add power steering during the project.
Have you ever wondered why the only thing common in all of your dysfunctional relationships is YOU?
Toddah is offline
post #580 of 783 (permalink) Old Sep 15th, 16, 6:42 PM
If you are converting from manual to power, then yes, you will have to replace the pitman arm with one for a Chevelle that had power steering. The holes aren't same size.
All the info is in the last 500 posts and you can search within just this thread for what you are looking for.
66partspile and streetperf like this.
Val_varo is offline
post #581 of 783 (permalink) Old Sep 17th, 16, 5:18 AM Thread Starter
James
Wow, this thread got long
69307/350Chevelle is offline
post #582 of 783 (permalink) Old Sep 18th, 16, 12:19 AM
Way too long for a simple conversion.
streetperf likes this.
Pete 67 is offline
post #583 of 783 (permalink) Old Oct 19th, 16, 10:06 PM
Doing the swap on a manual steering 66 el Camino. Got a 96 jgc used box with code wk on it. I also bought the lares 200 rag joint. The steering shaft seem a little to long. With every thing connected there is a gap between the steering wheel and colum.. anyone run into this?
T-Bag'n is offline
post #584 of 783 (permalink) Old Oct 19th, 16, 11:26 PM
Doesn't the steering wheel attach to the column? Hard time understanding the gap problem.
70 Chevelle
Becker is offline
post #585 of 783 (permalink) Old Oct 20th, 16, 10:03 AM
Verle
Is the rag joint on the steering box spline as far as it will go and is the steering shaft all the way in?
Did you compare the new rag joint (length) to the original? It is not impossible for the rag joint to be wrong even if the box has the right number.
Verle
Tulsa, Ok
Verle is offline
