Jeep box upgrade-PICS-and then some... - Page 3 - Chevelle Tech
 42Likes
post #31 of 791 (permalink) Old Jun 19th, 11, 6:48 PM
Vince
Re: Jeep box upgrade-PICS-and then some...
Hi,
I want to swap out my power steering box on my 1966 Chevelle (small block 327) as it has signifcant "play" in the steering. I have all new front steering and suspension and have adjusted the box, but have experienced no improvement.
Today I puchased a power steering box from a salvage yard, from a 1996 Jeep Grand Cherokee. According to prior postings this should have a KD alpa code. Now for my question, where do I find that code as I do not see that code on the steering box. Is it part of the VIN numer on the vehicle?
Thanks in advance.
Vince
VJG_MALIBU is offline
post #32 of 791 (permalink) Old Jun 19th, 11, 11:09 PM
The code should be on a bar-code label stuck to the top cover (with the four bolts and the adjuster in the middle), visible with the box installed.
- Eric
MDchanic is offline
post #33 of 791 (permalink) Old Jun 20th, 11, 12:57 AM
Vince
Thank you, as I was assuming it was a stamped code.
Vince
post #34 of 791 (permalink) Old Jun 20th, 11, 1:36 AM
Vince
The steering box I pulled from a 1996 Jeep Grand Cherokee does not have a sticker on top. Is there any other way to determine if this box may be a KD code steering box? Would the other (non KD) steering boxes from that vehicle be acceptable for my 1966 chevelle?
Thank you,
Vince
post #35 of 791 (permalink) Old Jun 20th, 11, 6:39 AM
You got me there.
All I know is that if it's a '93 (?) to '97 JGC box, it's supposed to have the right ratio.
The regular Cherokees (Sport, Laredo, etc.) are a slightly different body, and, as far as I know, have a less desirable ratio.
The one in the picture is a WK box from a '97.
Possibilities include that the label has just fallen off, or that the box was replaced at some point, in which case anything goes - it could be an exact replacement, only with low mileage (Score!), or it could be the wrong one because neither the parts guy nor the owner of a beat-up Jeep really cared.
Trouble is, it is nearly impossible to actually measure the sweep angle (you'll NEVER get it with a protractor) and the ratio. Turns lock-to-lock mean little, even if the sweep angles are equal, because an old variable-ratio box may have the same 3 or fewer turns, but will be 16 or 17:1 in the middle, where you drive, and tighter at the edges, where you don't care.
I don't really have any good suggestions for you, but someone else here might.
Do you know anything about the car it came out of? Did you actually see it, or did you just pick up the box? Its appearance may give you a clue, but I really don't know how to be sure.
- Eric
MDchanic is offline
post #36 of 791 (permalink) Old Jun 20th, 11, 7:40 PM
Vince
Hi Eric,
Thank you for all of your help. I pulled the steering box myself on Sunday morning from 1996 Jeep Grand Cherokee Limited at a U-Pull-It salvage yard. I still have access to the vehicle. I will probably try and return it for one that matches the suggested list.
Thanks.
Vince
post #37 of 791 (permalink) Old Jun 20th, 11, 10:24 PM
I guess I'd say that if the box seemed to match its surroundings perfectly in terms of rust and grime, then it was probably original, but if it looked cleaner than the stuff around it, it was probably a replacement unit.
- Eric
MDchanic is offline
post #38 of 791 (permalink) Old Jun 21st, 11, 2:13 PM
If you have the VIN, the build sheet with the options codes can be obtained from Jeep.com
70GS455 is offline
post #39 of 791 (permalink) Old Jun 21st, 11, 2:39 PM
A question for you guys that have done the swap. Does the Jeep box provide less assist than the stock Chevy P/S box? Been driving too many newer cars and find the one finger steering effort from back in the good ol' days to be too light for my taste. A heavier feel would be an added benefit, I believe.
Tan66Elkie is offline
post #40 of 791 (permalink) Old Jun 21st, 11, 6:24 PM
Vince
Scott,
I have access to the vehicle so obtaining the VIN is possible. How would I go about contacting Jeep to get a build sheet with the options codes?
Thanks for your assistance.
Vince
post #41 of 791 (permalink) Old Jul 6th, 11, 11:06 AM
I installed a GC box in my 64, the steering feels slightly quicker but still "floaty"...want more road feedback, more effort i guess
wht64 is offline
post #42 of 791 (permalink) Old Jul 7th, 11, 9:23 PM
Rock auto has a remanufactured steering box for 94.79
http://www.rockauto.com/catalog/moreinfo.php?pk=3027483
Nickel333 is offline
post #43 of 791 (permalink) Old Jul 8th, 11, 11:46 AM
I just scored a junkyard 97' WK box from a cash for clunkers jeep, $50 bucks
post #44 of 791 (permalink) Old Jul 8th, 11, 12:03 PM
Originally Posted by Verle View Post
This information was posted here by someone (don't remember who) thank you who ever it was.
PARTS LIST
DESCRIPTION PN SOURCE PRICE
GM steering coupler 62420 Lee Manufacturing $79.00
GM steering coupler bolt 7807271 SDPC 14.16
GM power steering fluid 89020661 SDPC 7.94
Dorman steering coupler 31011 Rock Auto 41.79
Lee high-pressure seat insert 40620 Lee Manufacturing 4.00
Lee low-pressure seat insert 40630 Lee Manufacturing 4.00
Earl's 18mmx1.5 O-ring 961956 Summit Racing 10.69
Earl's 16mmx1.5 O-ring 961955 Summit Racing 10.39
Earl's steel 90-degree -6 139106ERL Summit Racing 18.39
Earl's P.S. -6 hose, 6-foot 130606ERL Summit Racing 44.99
GM power steering fluid 89021184 SDPC 4.13
1992-98 Grand Cherokee Fast Ratio Power Steering Gears
YEAR ALPHA CODE ORIGINAL APPLICATION GEARRATIO EFFORT T-BAR SIZE TRAVEL
1992.5-93-94 AL Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
1995 JH Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
1996 KD Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
1997-98 WK Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
Lee Manufacturing 888-698-6679 http://lee-powersteering.com/steering-gears.htm
Rag joint from:
1977 thru 1982 Chevrolet and GMC C/K (2 wheel and 4 wheel drive) Pickup Trucks
1977 and 1978 Camaro, Firebird, and Nova
1979 Nova
1983 thru 1986 Chevrolet and GMC C (2 wheel drive only) Pickup Trucks
Im a little confused by this list of parts. Do I need all these high dollar steering couplers or do i need the cheapo autozone #200 coupler?
Also If i do AN fittings i shouldnt need the Lee press in seat inserts, correct?
post #45 of 791 (permalink) Old Jul 8th, 11, 9:47 PM
Vince
Hi,
I am in the middle of swapping the steering box on my 1966 Malibu from an original sloppy box for a late model Jeep Grand Cherokee steering box. I scored a KW box from a 97 JGC for $40 from a salvage yard. I purchase steering "coupler/rag joint" part from AutoZone (31011) for $44.
Now I need to figure out the lines. For the low pressure line I used the return line from the JGC box with a little bending it should work fine. For the high pressure line I will probably buy a new JGC line that has the correct fittings ($20). I need to get the fitting from the back of the JGC pump where the high pressure line connects to make it work. All of the fittings listed in the above file address for various combinations.
Vince
