Jeep box upgrade-PICS-and then some... - Page 2 - Chevelle Tech
 38Likes
post #16 of 769 (permalink) Old Feb 24th, 11, 4:46 PM
Re: Jeep box upgrade-PICS-and then some...
93 to 98 Grand Cherokee - is the bolt-in.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is online now
post #17 of 769 (permalink) Old Mar 7th, 11, 1:36 PM
Could someone please post a part number for this box. The boxes are different with different engine sizes. Or do you know which engine size you used when ordering steering box. Thx.
bpb7272 is offline
post #18 of 769 (permalink) Old Mar 7th, 11, 4:43 PM
Verle
This information was posted here by someone (don't remember who) thank you who ever it was.
PARTS LIST
DESCRIPTION PN SOURCE PRICE
GM steering coupler 62420 Lee Manufacturing $79.00
GM steering coupler bolt 7807271 SDPC 14.16
GM power steering fluid 89020661 SDPC 7.94
Dorman steering coupler 31011 Rock Auto 41.79
Lee high-pressure seat insert 40620 Lee Manufacturing 4.00
Lee low-pressure seat insert 40630 Lee Manufacturing 4.00
Earl's 18mmx1.5 O-ring 961956 Summit Racing 10.69
Earl's 16mmx1.5 O-ring 961955 Summit Racing 10.39
Earl's steel 90-degree -6 139106ERL Summit Racing 18.39
Earl's P.S. -6 hose, 6-foot 130606ERL Summit Racing 44.99
GM power steering fluid 89021184 SDPC 4.13
1992-98 Grand Cherokee Fast Ratio Power Steering Gears
YEAR ALPHA CODE ORIGINAL APPLICATION GEARRATIO EFFORT T-BAR SIZE TRAVEL
1992.5-93-94 AL Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
1995 JH Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
1996 KD Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
1997-98 WK Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
Lee Manufacturing 888-698-6679 http://lee-powersteering.com/steering-gears.htm
Rag joint from:
1977 thru 1982 Chevrolet and GMC C/K (2 wheel and 4 wheel drive) Pickup Trucks
1977 and 1978 Camaro, Firebird, and Nova
1979 Nova
1983 thru 1986 Chevrolet and GMC C (2 wheel drive only) Pickup Trucks
Verle
Tulsa, Ok
Verle is offline
post #19 of 769 (permalink) Old Mar 7th, 11, 11:31 PM
Thx for the response but the guy at the O'reillys counter only knows how to find parts by make,model,year, and motor. Is this steering box any smaller than my original 72 box? Thanks again for your help.
bpb7272 is offline
post #20 of 769 (permalink) Old Mar 8th, 11, 2:40 PM
for the Earls o-rings for easier reference
http://www.summitracing.com/parts/EAR-961955ERL/
http://www.summitracing.com/parts/EAR-961956ERL/
I think I may do this, as my hoses are nasty and dont route where I would like them to.
68 chevelle 355 [email protected]
78 malibu 454 on E-85 [email protected]
496malibu is offline
post #21 of 769 (permalink) Old Mar 9th, 11, 10:21 PM
While I was pulling the steering box of the jeep today, I noticed the power steering pump looked like a lsx pump. All I needed to do was pull the pulley off and reinstall it backwards,and it fit into the ATI Procharger power steering relocator kit. $80 bucks at the local LKQ was all it took to get back on track with my Procharged LQ4 72 chevelle project. Thanks Guys!
bpb7272 is offline
post #22 of 769 (permalink) Old Mar 13th, 11, 11:33 PM
I did the swap today using a 1998 JGC box rebuilt from autozoneEverything hooked up fine except I am having a n issue with the pitman arm.It appears that the shaft on the JGC box is smaller than the inside diameter of the original 1967 Chevelle pitman arm and it is a very sloppy fit.I do not beleive that my arm is gonna work with this box,because it will not spline up properly.Has anybody seen this before and if so what was the remedy.Im stuck until I get an answer.I was using a 1998 JGC Box,Lees line adapters and original PS hoses from remote resovoir.Help me out guys
fishman is offline
post #23 of 769 (permalink) Old Mar 14th, 11, 9:48 AM
Kevin
Did this swap over the weekend using a junkyard jeep box and the $10 advance rag joint.
The difference is AWESOME. Excellent road feel, no slop, and the quick ratio is an excellent bonus. Mine is barely over 2 turns lock to lock (might be limited a hair due to oil pan/tie rod clearances).
I now just need to find a pressure line that has a straight 2" o-ring joint on the pump side (99 corvette PS pump, curved lines won't work) and jeep fitting on the box side. Right now I'm using a compression fitting like I was on my stock box to join 2 different lines on the hardline section right before the box.
Pro Touring 1971 Chevelle SS clone
head/cam LS2, 4l60e, 3.42 12 bolt
1.61 60ft [email protected] 1/8th [email protected] 1/4
thunderstruck507 is offline
post #24 of 769 (permalink) Old Mar 19th, 11, 2:38 AM
Great read. ordering tonight
Tim
true 70 SS but convertible clone
90 38 Scarab
05 Dirtymax
TDSRacing is offline
post #25 of 769 (permalink) Old Apr 9th, 11, 4:45 AM
Send a message via AIM to pealer
I've been wanting to do this swap for awhile but I don't have any power steering equipment whatsoever. Mine's a 66 with a big block but doesn't have a power steering pump or anything. I've read that the reservoir needs to be mounted externally, on the radiator support I think, for this to work due to space limitations. Does anyone know what else I would need, or more accurately, what part numbers or where to get them for this setup? Thanks for any info anyone can provide.
pealer is offline
post #26 of 769 (permalink) Old Apr 9th, 11, 5:53 AM
This is one way to do it:
http://www.chevelle.com/1965-1968-BB...P5139C643.aspx
or find a used setup on eBay/Craigslist/etc. You'd need a power steering box, of course ...
David
davewho1 is offline
post #27 of 769 (permalink) Old Apr 19th, 11, 4:09 PM
Ralph
Recently, I read an article on the Jeep swap-over and it mentioned that you have to change the pressure valve in the stock GM PS pump to the higher pressure valve. However, I don't remember ever reading that in any of the forums. Can someone shine a light on this for me? When you swap over to the Jeep box and you use the original PS pump, did anyone change the pressure valve in the pump to the higher pressure valve? Or, did the stock pump work OK with just the hose change-over? Thanks!
sglide is offline
post #28 of 769 (permalink) Old Apr 30th, 11, 12:20 PM
The pressure valve is set to 950psi in pre-1970 cars, 1450psi in '70 and up, according to Jim Shea. If you've got a '70 or later car, you're fine, if not, you've got to take the pressure valve from the donor car, which is the fitting the pressure hose threads into on the back of the pump - it just unscrews. As an added bonus, a later pressure valve will have the later O-ring seal, but the pump end will be the same and will thread into your existing pump.
- Eric
MDchanic is offline
post #29 of 769 (permalink) Old May 5th, 11, 6:25 PM
Ralph
Thanks!
sglide is offline
post #30 of 769 (permalink) Old Jun 13th, 11, 2:49 PM
Elroy
thanks guys for posting. My son is doing this one as well on his 66 Camino so we will try it and see how it goes !
66138 is offline
