Disk Brakes for 66 - Chevelle Tech
post #1 of 4 (permalink) Old Mar 15th, 03, 8:15 PM Thread Starter
Post
Will the 73 malibu spindles, rotors, etc work for a 66 chevelle disk brake conversion? Everything I see only goes to 72.
Looked all over today, can't find any 69-72 a-body donor. They must be gold!
Any help appreciated!
mattchas is offline
post #2 of 4 (permalink) Old Mar 15th, 03, 8:20 PM
David
Post
nope, will not fit. spindles are wrong
david_396 is offline
post #3 of 4 (permalink) Old Mar 16th, 03, 9:19 AM
Bruce
Post
The 73 to 77 A-body spindles are the same tall spindles used on the B-body cars. The 73 Malibu spindles use 11 inch rotors. These can be adapted to the earlier A-bodies but require a turned down lower ball joint and the tie rod ends and ball joints from the later cars. There is lots of information on this website about tall spindle conversions.
66 El Camino 396/325HP 4-Spd
My Build Thread:
62 Corvette 327/360HP (original RF engine and Fuel Injection) (future restoration project)
66 Corvair My son's project. Small block, Powerglide, C5 differential and rear suspension
72 Chevelle wagon project
AZCamino is offline
post #4 of 4 (permalink) Old Mar 16th, 03, 11:29 AM
Post
Wasn't there also a post with all of the spindles that will work, even if you need to turn the lower ball joint?
We know we can make the S-10 2" Dropped Superior Spindles we have work by turning the lower ball joints, and really don't see a problem with turning it (Plus turn a spare set at the same time). However, you can't get as large a rotor on the S-10 Spindles.
We replyed to a post about these spindles the other day in the Global West Group Purchase.
A local Chevelle enthusist told us the other day that you can also use '78-'87 Elke spindles, but we wouldn't know if that info is correct or not.
[img]graemlins/beers.gif[/img]
'99 Firebird (Bad Bird 2). Installing the Motor/Trans/Canton Accusump Pre-Oilong System/Accell 300+ Digital Ignition from the Elke into the car. "FAST"
MAXX2 is offline
This Thread is more than 6356 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
