proportioning valve button - Chevelle Tech
post #1 of 6 (permalink) Old Jun 11th, 04, 11:40 PM Thread Starter
Post
what does that button in the back of the valve do..70 chevelle SS
1970 Chevelle SS 396
2004 Intimidator Monte Carlo SS
1992 K5 Blazer SS
vendo is offline
post #2 of 6 (permalink) Old Jun 12th, 04, 2:51 PM
Post
The button is so that you have a way to re-center the piston in the valve that turns on your brake warning light. This works off of pressure differential between the front and rear halves of the valve. Sometimes the pin needs to be pushed in to allow one side or the other to be bled out. Hope this helps
a36chevy is offline
post #3 of 6 (permalink) Old Jun 12th, 04, 9:18 PM Thread Starter
Post
I am talking about the valve under the master cylinder..are you?
vendo is offline
post #4 of 6 (permalink) Old Jun 13th, 04, 4:29 PM
Post
I think '70 used this system. The roundish looking device (with the big hex nut on its front) hanging below the master cylinder is the Metering Valve. Its button needs to be held in (probably with a C-clamp) when pressure or vacuum bleeding the front brakes.
The proportioning valve is down on the frame and does the distributing forward and rear. It also has the "BRAKE" warning light switch. I have no idea if there is also a "reset" button on that dist. block...if there is, I can't find it.
'69Larry is offline
post #5 of 6 (permalink) Old Jun 14th, 04, 9:08 PM
Post
my driverside front is locked but the other 3 work. i just changed to discs any of you guys have any ideas
jocww is offline
post #6 of 6 (permalink) Old Jun 15th, 04, 5:38 PM
Post
Faulty caliper, did you grease the slide pins, something caught in the caliper?
68joker is offline
This Thread is more than 5736 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
