KYB shocks vs drag shocks - Chevelle Tech
post #1 of 3 (permalink) Old Mar 10th, 03, 6:30 PM Thread Starter
Post
ok, i have been reading up on how to get better traction.
now i have read alot about 50/50 shocks and 90/10 shocks etc... Now i have KYB gas shocks all around. what is the differance? how good are the KYB's with racing? (drag racing)
scottie
CULater69 is offline
post #2 of 3 (permalink) Old Mar 12th, 03, 9:24 PM
Tim
Post
Might be better off asking in the performance forum, if you haven't.
I think the KYBs should be fine to point. How fast is the car? Front shocks are probably more important. The rear just needs something that won't collapse. Front shocks have to let the front up and then down at a good rate to help transfer the weight to the rear.
Tim.
Proud Owner: '69 Chevelle
Malibu: 454, Richie 5, 3.42 posi
TronDD is offline
post #3 of 3 (permalink) Old Mar 14th, 03, 2:35 PM
Send a message via AIM to mc71454
Post
Scottie,
KYB's are all you need at least into the 11.00 second range.
Tom B
'71 540 Street/Strip Monte Carlo 10.310, @ 129.86, Pump Gas, Full Exhaust (Under Frame off Rebuild)
'70 Chevelle, 462, 3.42's, 12.35, 1.66 60', 107.0 4020 lbs. Full exhaust, Pump Gas
'87 Regal Limited Turbo T, Chip & Dual exhaust - 13.08, 1.78 60'
'75 Laguna S3, 454 HYD Roller
'72 Buick GSX Clone (looking for a 455)
'81 Malibu Wagon 6.0 LS 3.73's under construction
2015 Tundra TRD Pro Supercharged 5.7
mc71454 is offline
This Thread is more than 6162 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
