67 Chevelle, do I need new springs? - Chevelle Tech
post #1 of 6 (permalink) Old Dec 16th, 09, 4:03 AM Thread Starter
Send a message via AIM to Malibulvr Send a message via Yahoo to Malibulvr
Ok, I have a 67 Chevelle that is having some work done to it. The 350 and powerglide are coming out and a big block with aluminum heads,intake,pulleys and radiator is going in its place. I will also be installing a 6 spd from Keisler. The front springs (for a small block originally) currently on the car are new, could I still use them with the new setup? The spindles are stock and I'm looking for a stock ride height minus 1/2".
Thanks in advance,
Malibulvr is offline
post #2 of 6 (permalink) Old Dec 16th, 09, 10:33 AM
Re: 67 Chevelle, do I need new springs?
Since the springs are new, I would say see how the car sits with the new engine in it. Might be just right. No need to buy srpings and go through the effort to remove and replace them if you don't have to.
TXCR13
1966 Chevelle 300 2dr Sedan
385, Flat Top Hypers, Performer RPM, S.M.I. 750 Q-Jet, 72cc Dart Platinum 200cc runners, U.D. Harold 223/233 112 LSA Cam, 700-R4, PS, Manual Disc Brakes, AC, Hedman headers with 2-1/2" exhaust.
1946 Studebaker Coupe- street gasser finally underway!
TXCR13 is offline
post #3 of 6 (permalink) Old Dec 19th, 09, 10:19 PM Thread Starter
That is what I was thinking but wasn't too sure. Anyone else have a clue???
post #4 of 6 (permalink) Old Dec 19th, 09, 11:54 PM
For what it's worth, the OPG catalog lists the same spring for SB or BB. What appears to change the spring is whether or not the car has AC. So, I agree - leave 'em and see if you are happy with how it sits.
carcia is offline
post #5 of 6 (permalink) Old Dec 20th, 09, 2:23 AM Thread Starter
Now that I didn't know, no AC on this sucker, should be good to go, lol
post #6 of 6 (permalink) Old Dec 20th, 09, 7:58 AM
Send a message via Skype™ to marooned
New springs on my 65 raised it close to 2 inches from old tired ones. They tend to settle just a little bit. There is a 1" spacer available if it sits too low.
Before
After
TC #415
Mike Norman
1965 Chevelle Convertible
When you find yourself in a hole........ Stop digging.
marooned is offline
This Thread is more than 3690 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
