How much rake looks best & how to measure? - Chevelle Tech
post #1 of 12 (permalink) Old Dec 15th, 09, 12:53 PM Thread Starter
Tires are 28" tall all around.
Right now my front looks to be about 2" lower than back, but I'm not clear on where to measure?
Using a 4' level, it's a little more than a full bubble lower in front.
No room in garage to take a decent pic. & car won't be started until Spring.
Bottom of body outside frame to floor at max. distance between wheels is: Front 10" Rear 11.25"
Front springs are about a 2" drop & pretty stiff at about 555#
I put in rear springs about 25 years ago & think they are some sort of HD or Cargo Carriers.
I just tried a set of Black Magic 11" 175# in the rear, but that was too low, I will guess about 1" lower than front. Might look good with 1.5" stools?
BBP
Buffalobillpatrick is offline
post #2 of 12 (permalink) Old Dec 15th, 09, 1:23 PM
Bobby
Re: How much rake looks best & how to measure?
What year? Also keep in mind if you have a slope to the floor of the garage, my 65' sits about 3/4-1" lower in the front, any more and the tail looks to be sitting too high.
The 68-72 cars seemto be able to get away with more rake as the tail is more rounded.
-Bobby-
1965 SS 331 Muncie
Lilracr is offline
post #3 of 12 (permalink) Old Dec 15th, 09, 1:29 PM Thread Starter
72 Monte
I sometimes post here as this site has about 50X the activity as the firstgenmc.com
Thanks BBP
post #4 of 12 (permalink) Old Dec 15th, 09, 1:42 PM
Bobby
You can get away with 2" of rake on a MC, they look good dropped all the way around with 10" wheels and skinnies on the front also.
I have had several Monte's through the years.
-Bobby-
1965 SS 331 Muncie
Lilracr is offline
post #5 of 12 (permalink) Old Dec 15th, 09, 2:24 PM
mike
Ask 100 people and get as many answers--YOU are the one that should know what you like, how can someone else decide for you? Some people like nose up, some down, some level--depending on the vehicle, I like all of them. We build altered wheelbase 60's style cars with sky high, nose up stances, but my personal stuff is usually low and nose down. My 64 Chevelle wagon is going to be nosebleed high and level.
bowtie0069 is offline
post #6 of 12 (permalink) Old Dec 15th, 09, 6:28 PM
Jamie
I always wanted to build my 63 Nova wagon into a 60s altered.
1967 Chevelle 300 Deluxe
67300Dlx is offline
post #7 of 12 (permalink) Old Dec 15th, 09, 9:26 PM
Where are you putting that level? I don't know of any flat spots to put a level. As far as rake goes I would start by putting a shorter tire on the front. 28" tis awful tall, most are around 26". a 2-3" drop looks good to me if the wheel wells are filled evenly.
I never make mistakes, but on occasion I present myself with an opportunity to get very creative.
animal69 is offline
post #8 of 12 (permalink) Old Dec 16th, 09, 2:50 AM Thread Starter
Level along bottom of body outside frame under door.
I could put 2 of my new Hankook Ventus V12 evo K110 245/45ZR17 on the front. 25.7" tall.
I don't know how it would handle with the rears: Falken ZIEX S/TZ-01
275/50/r17 28" tall.
BBP
post #9 of 12 (permalink) Old Dec 16th, 09, 1:57 PM Thread Starter
I know that what counts is "when it looks best to me"
I guess by the lack of answers on "how to measure drop" that there must not be a consensus or standard method.
Searching for: crossmember ground clearance provides information.
BBP
post #10 of 12 (permalink) Old Dec 22nd, 09, 6:46 PM
Stu
I like zero rake, completely level best. Measure with a level along the bottom of your door. That is the correct answer. (Or is it?)
chuckd71 is offline
post #11 of 12 (permalink) Old Dec 22nd, 09, 7:42 PM
"Wild Bill"
I always measure from the wheel lip straight down thru the center of the axle/spindle to the level ground...as perpendicular to the ground as possible.
Depending on the car, this method will measure anywhere from 23 to 27 inches.
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #12 of 12 (permalink) Old Dec 23rd, 09, 12:04 PM
I use this method to verify I have an equal drop from side to side also... this can be a problem if you didn't index your springs in the LCAs properly... forgot how many shims you used on your SPC LCAs... adjusted your speedway adjusters wrong, or one slipped while installing... the list goes on and on. Nothing worse while trying to work on your stance, you have a nasty lean as well.
'69 SS396 - FiTech L33 swapped w/Muncie, 3.31 TrueTrac - VHX Gauges.
Originally Posted by Busted Knuckles View Post
Being politically correct is kinda like trying to pick up a turd by the clean end.
GenPac is offline
This Thread is more than 3687 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
