Another '72 Chassis Build - Chevelle Tech
post #1 of 6 (permalink) Old Dec 5th, 09, 11:00 PM Thread Starter
Doug
It seems there are always a few threads running on chassis rebuilds. I always enjoy taking a look to see what others are doing and steal their ideas. After this weekend, we are finally in a position to share our build. It's a start...
The Before:
The After:
Here is the rundown for the suspension;
Front
SpeedTech Tubular Control arms
QA1 Coil-over conversion
Right Stuff Stock height Spindles
Wilwood 4-Piston Disc (Drilled/Slotted) Brakes
UMI Performance Sway Bar
AGR 12:1 Steering Box
Rear
UMI Performance tubular lower control arms
UMI adjustable upper control arms
UMI control arm reinforcers
BMR 2" drop coil springs
QA1 adjustable shocks
Wilwood 4-Piston Disc Disc (Drilled/Slotted) w/e-brake
There are some things we would do differently, but I don't think it looks too bad as is and should perform well.
-Doug
1972malibu is offline
post #2 of 6 (permalink) Old Dec 6th, 09, 1:00 AM
thomas
Re: Another '72 Chassis Build
Looks great.
ls5-70ss is offline
post #3 of 6 (permalink) Old Dec 8th, 09, 12:25 AM Thread Starter
Doug
Thanks Thomas... It's a work in process.
-Doug
post #4 of 6 (permalink) Old Dec 18th, 09, 11:53 PM Thread Starter
Doug
The new brake lines arrived today. Not quite as plug and play as I thought, but with some maniulating I think I can get them in place. Something is wrong with the front-to-back line though. The fitting on the line is way smaller than the output on the proportion valve. I'll give Todd or Bear a call tomorrow and see if we can get it figured out. - Doug
post #5 of 6 (permalink) Old Dec 19th, 09, 10:17 AM
Ray
Doug, I have seen two sizes on the proportion valve. I have the the smaller one on my car and a replacement one I got had the larger fitting. I went with the smaller one so I could hook up my brake lines. You could install a reducer at the valve to fit the brake line. Also your frame looks great.
Ray
70 SS Chevelle Van Nuys Cal Built
shadowgray396 is offline
post #6 of 6 (permalink) Old Dec 19th, 09, 3:04 PM Thread Starter
Doug
Ray
Thanks Ray. I'll see if I can pickup a reducer and finish the mock-up. I'm wishing I had gone with the more original line configuration with the proportioning valve on the frame, but it will work and should give a little extra room for the headers.
Thanks again,
Doug
This Thread is more than 3692 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
