Boxed rear control arms - Chevelle Tech
post #1 of 7 (permalink) Old Feb 25th, 03, 8:15 PM Thread Starter
Kirk
Post
Okay, this is an oddball question. I removed boxed rear control arms from a 75 Monte. Got the sway bar too. The bar mounts on the BOTTOM of the arms...not to the side. Had planned to install the whole setup on my 68. BUT it turns out that the bar won't fit...apparently the spacing of the arms on the Monte is different than a Chevelle. Aaargghhh!
I've already installed poly bushings in the arms and boxed in the portions that weren't boxed in already (the original config just had them boxed where the bar mounted, not all the way along the length), so I don't want to ditch the arms. I was thinking that I could probably just drill the arms for a standard bar and be okay. I'm not familiar with exactly what the boxed arms look like from the factory, but I think they are just boxed in to keep them from collapsing...not reinorced in any way in the bolt holes. Is this correct? Anyone see any issues with popping holes in my already boxed arms as described???
ssbums is offline
post #2 of 7 (permalink) Old Feb 25th, 03, 10:56 PM
MAX
Post
Huston..... We have ISSUES. Yes, you will have problems if you only drill mounting holes in boxed trailing arms. If you're going to do it, drill the holes in your trailing arms large enough for the outside diameter a piece of pipe/tubing that has the correct inside diameter for the bolt size that originally came with the sway bar you're using. Probably 7/16.Cut pieces of pipe to fit in the holes from one side of the trailing arm to the other, just below flush on both sides. Weld the tudes in place. Now the trailing arm won't crush when you tighten the sway bar bolts. It's real easy but hard to explain with nothing but text. Max
MAX is offline
post #3 of 7 (permalink) Old Feb 25th, 03, 10:59 PM
Hoarder Deluxe
Post
I believe the 73 up control arms are also longer than the 68-72 pieces so you may be SOL with even using the arms. Should of asked us first [img]smile.gif[/img]
66/68/70 chevelles
55/57/61 belairs
69 70 71 72 novas
37 Buick 47 Cadillac 51 Ford F1s
other money pits and projects
drptop70ss is offline
post #4 of 7 (permalink) Old Feb 26th, 03, 11:32 AM
wagons rule!
Pete
Location: In the Beautiful mountains of western North Carolina
Post
i am pretty sure the lca are the same. just hold them up to the chevelle arms, if the holes are the same distance apart, they should work. i believe i have a set of those and did that. they were the same between the holes. unless you see a difference dont rule them out yet. you have to mount the control arms in the car before you install the sway bar. it has slots in it to adjust for variations in arm seperations.
FO_FDYFO is offline
post #5 of 7 (permalink) Old Feb 27th, 03, 1:30 AM Thread Starter
Kirk
Post
FO_FDYFO
Yes, the rear arms are the same. I checked all of that before I did all the work. Just made the wrong aassumption on the bar location. I'm backed into a corner now since I welded them up already and can't move the u-channel. Well, I do have a grinder, so I guess I can go that route (carefully!) if I have to.
So I'm just trying to figure out how to get myself out of the mess inexpensively and without too much pain.
MAX, I thought that it might be wise to weld some tubing in the bolt holes if I use the standard bar...you confirmed it.
I know better than doing what I did. Stupid, stupid, stupid. Could've been worse I suppose!
ssbums is offline
post #6 of 7 (permalink) Old Mar 3rd, 03, 1:28 PM
wagons rule!
Pete
Post
ssbums, you can call me if you like 703-549-2412.
i measured my arms. amagine the arms in the car, drill a 1/2 hole 1.5 inches forward of the center of the rear bushing. the next hole is 5 more inches forward of that. accuracy is not that critical.
pete
FO_FDYFO is offline
post #7 of 7 (permalink) Old Mar 12th, 03, 9:49 AM
wagons rule!
Pete
Post
this is how my arms are welded. i drilled a drain hole in the bottom, and you can see the 2 holes for the swaybar.
btw FO_FDYFO is ebonics for four fifty four.
Web Master,
wagon parts and info only at
FO_FDYFO is offline
This Thread is more than 6162 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
