question on SSM lift bars - Chevelle Tech
post #1 of 3 (permalink) Old Mar 1st, 03, 9:01 PM Thread Starter
Post
ok, i had bought and installed SSM lower Boxed arms a while back. (about a year)
I was wanting to know if i should switch to the
"Lift Bars"?
I'm running a 1969 chevelle stock rear.
I have the SSM upper and lower box arms in now.
I had put new springs in, Hotohkis i think, front and rear and all new front susp. poly.
I have air bags in rear springs.
the motor is going to be a 500hp / 500ft-lbs 383.
what do you think would be good?
scottie
CULater69 is offline
post #2 of 3 (permalink) Old Mar 2nd, 03, 11:10 AM
Post
Unless you have problems with wheel hop, I'd leave it alone. The only reason I put in lift bars is even with boxed lowers (stock AND hotchkiss) I had massive wheel hop with my 4 speed.
I wouldn't change until you need too. (and if you're lucky, you might never need to......) [img]smile.gif[/img]
chris
bulb122 is offline
post #3 of 3 (permalink) Old Mar 2nd, 03, 7:17 PM Thread Starter
Post
Cool thats what i'm hoping!
but just didn't know with the 500 lbs of TQ from the new motor.
scottie
This Thread is more than 6335 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
