67-69 CAMARO SPINDLES/ 68-72 A BODY? - Chevelle Tech
post #1 of 3 (permalink) Old Jun 15th, 04, 2:28 PM Thread Starter
Post
Are the 67-69 Camaro drum brake spindles the same as 68-72 A body drum brake spindles? Thanks, Scott! [img]graemlins/hurray.gif[/img]
scottysalesman is offline
post #2 of 3 (permalink) Old Jun 15th, 04, 5:30 PM
Post
Maybe they are same. One way to check is by the two large bolts and nuts holding the spindle to the steering linkage. I tried an explaination in this thread comparing older and newer spindles.
https://www.chevelles.com/cgi-bin/for...7;t=006633;p=2
John_Muha is offline
post #3 of 3 (permalink) Old Jun 16th, 04, 10:27 PM
Post
I believe they are the same you just have to use the chevelle steering arm. I know this is true with the Novas because the steering linkage is behind the engine crossmember.
BlueSS454 is offline
This Thread is more than 5834 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
