Posi additive and gear oil suggestions - Chevelle Tech
post #1 of 11 (permalink) Old Jun 7th, 04, 7:03 PM Thread Starter
Rod
Rod
Post
I just picked up the newly rebuilt 12 bolt with an Eaton posi. No fluids in it yet and need some ideas. I was thinking of non-synthetic with a posi additive to start and later switching to a sythetic. Fluid recommendations? How long till I can switch? Do I need additive with sythetic? Any brand names I should or should not use?
Rod Jamieson
1970 Chevelle 454
1996 LT1 Caprice
2005 GMC Sierra
Team Chevelle Gold #22
Rod is offline
post #2 of 11 (permalink) Old Jun 7th, 04, 8:05 PM
Mark
Post
I think you're on the right track to break it in with regular oil and then switch to synthetic. I use Mobil1 because it is 100% synthetic. Others like Amsoil and Royal Purple are the same, but not all are 100% synthetic FYI. If you use the full synthetic you won't need the additive.
Xtreme70SS396 is offline
post #3 of 11 (permalink) Old Jun 7th, 04, 9:44 PM
Post
Rod I just did the same thing today. I put in Valvoline 85-90, with the two little bottles of friction reducer that came with the Eaton unit.
Sound right guys?
Put the rear in after work and tomorrow all that is left is brake shoes and springs, bled'em and break it in.
Any recomendations on break in?
ACLineman is offline
post #4 of 11 (permalink) Old Jun 7th, 04, 11:19 PM
Justin
Post
Sound right guys?
Same exact thing I did...two bottles of friction reducer and Valvoline 80-90. I forget when you're supossed to change it out after break-in, anyone remember?
-Justin-
70 Chevelle SS 454 clone
GMPP 454HO
Tremec 5 speed
3.42 gears, Eaton posi
100 shot N2O
70 Chevelle Malibu (stock)
Numbers match L48, 300HP
Original M20 trans
Original 12 bolt rear
Complete documentation
69 Chevelle SS 396 (sold)
"If it doesn't go, force it. If it breaks, it needed fixing anyway!"
Got_CID? is offline
post #5 of 11 (permalink) Old Jun 8th, 04, 12:11 AM
Post
I just got done doing my rear end today i installed a posi unit w/4:11 gears which i bought GM posi differental additive for $5.99 from modern cheverolet in winston-salem NC know to everyone Classic Muscle its some great additive that GM uses but also you can use lukas oil treatment also but if i was you i would use 80-90w gear oil w/limited slip additive because sytectic oils cost more and does not make a difference.
Chevyboy is offline
post #6 of 11 (permalink) Old Jun 8th, 04, 9:28 PM
Send a message via AIM to Resq302
Post
Is all posi units supposed to have two bottles of the friction additive put in? I have always been putting in one
Resq302 is offline
post #7 of 11 (permalink) Old Jun 8th, 04, 9:47 PM
Post
I never had a posi but, the eaton unit came with 2 so that's what I out in.
The guy who set this up for me kept all the paper work and I was so excited to get it back I forgot to get the papers from from him.
Hope someone answers these questions...
post #8 of 11 (permalink) Old Jun 9th, 04, 10:46 PM
Post
[/qb][/QUOTE]Same exact thing I did...two bottles of friction reducer and Valvoline 80-90. I forget when you're supossed to change it out after break-in, anyone remember? [/QB][/QUOTE]
Anybody??
post #9 of 11 (permalink) Old Jun 11th, 04, 10:35 PM
Post
AC, I hope someone else can confirm this, but I don't think you need to change it out right away.
As for break in, many gearsets will have a recommended break-in period before you tow with them or hammer on them. Some figure 8's to work the posi unit in. Don't put alot of miles on it initally, and let it cool between uses. Short hops with a cool off period. That's the way I was told to break it in.
If Big Gear Head sees this , he'll correct any errors.
post #10 of 11 (permalink) Old Jun 14th, 04, 9:17 PM
Post
Thanks man.
post #11 of 11 (permalink) Old Jun 14th, 04, 10:30 PM
Justin
Post
I thought it was something longer, like 100 miles or something. Oh and I think the 2 bottles of friction modifier was only for the inital break-in, and its fine to use only one after that.
Got_CID? is offline
This Thread is more than 5832 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
