Proportioning valve and adjustable valve - Chevelle Tech
post #1 of 8 (permalink) Old Feb 21st, 01, 1:06 PM Thread Starter
I am in the process of reassembling my 65 El Camino and am redoing the braking system.
Before I started the restoration and was driving the vehicle, I had converted to a 72 power disc brake setup with dual reservoir and porportioning valve. I also had plumbed in a Wilwood adjustable valve on the rear brake line to better balance the brake system. This arrangement worked great and I had a balanced system.
I my decision now is to remove the 72 proportioning valve and use only the Wilwood adjustable valve and a residual 10lb pressure valve on the rear line from the output of the MC rear resevoir. The front line will come out of the MC front resevoir to a distribution block to split off to the two front discs. I was told this would be okay by the Wilwood mfg. Susposedly this is the setup used on track cars for balancing the brakes.
I would like some confirmation from you guys that I can balance the system with this setup. Also I would like to confirm that the front most resvoir is for the front brake lines and the rear (closet to the firewall) is for the rear lines.
Brian TC#1092, ACES#4374
My Garage
1964 Malibu SS Convertible (Restored Garage Queen)
1965 El Camino (Current project)
1974 Midget (Next project, maybe)
1981 Corvette (Daily driver)
65elcamino is offline
post #2 of 8 (permalink) Old Feb 22nd, 01, 11:36 AM
I have this on my 68 Chevelle hardtop and it works fine.
bigdog454 is offline
post #3 of 8 (permalink) Old Feb 24th, 01, 5:20 AM
im sorry i cant help you,but i am wanting to do the same brake conversion ,what is involved? and will my rally rims still fit on the front? thanks for any information you can give me.
gregt is offline
post #4 of 8 (permalink) Old Feb 26th, 01, 1:09 AM
Okay here is the straight scoop. It will work great Wilwood knows there ****...
motor_head is offline
post #5 of 8 (permalink) Old Feb 26th, 01, 12:36 PM
Brian,
Outta curiousity, why do you want to remove the proportioning valve?
Phocks
phocksphyre is offline
post #6 of 8 (permalink) Old Feb 26th, 01, 12:41 PM Thread Starter
Cleaner installation, less connections, and easier access to the adjustable valve without the proportioning valve in the way. Also I do not use the brake light indicator signal output.
post #7 of 8 (permalink) Old Feb 26th, 01, 12:43 PM
The factory was taking into account the OE tires and organic front pads with their set calibration of the proportioning valve to limit presure to the rear brakes to prevent premature lockup. With an adjustable you can set the max pressure before lockup to take advantage of best possible braking and customize it to exactly what you have (or have changed) over stock.
post #8 of 8 (permalink) Old Feb 26th, 01, 5:46 PM
I use only the adjustable valve as my car had drums, works great I have set it so there is no rear lock up.
gregt if your ralleys are the ones used for drum brakes they will not clear the calipers on a disc setup...FRED
Fred Ont canada is offline
This Thread is more than 7036 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
