12 bolt Hotchkis bushing install help needed - Chevelle Tech
post #1 of 4 (permalink) Old Jun 13th, 04, 5:10 PM Thread Starter
Rod
Rod
Post
I am putting in the Hotchkis upper control arms and have a couple questions on the bushing that goes in the rear end.
(1)The bushings come with a ring of rubber/graphite that slides on the bushing, does it go on before or after the bushing is in place on the rear end?
(2) I am trying to figure the best way to press in the bushing in my 12 bolt, any ideas that will make this work?
Rod Jamieson
1970 Chevelle 454
1996 LT1 Caprice
2005 GMC Sierra
Team Chevelle Gold #22
Rod is offline
post #2 of 4 (permalink) Old Jun 13th, 04, 9:51 PM
Post
with those rings you put the ring on after the bushings in and with the 12 bolt on one side you have to trim the ring for it to fit... just the way they are designed. I got mine in by freezing them overnight it shrinks they down a bit and then i brought out the BFH! the rearend bushings actually went in a lot easier than the fronts
69chevelle69 is offline
post #3 of 4 (permalink) Old Jun 14th, 04, 8:23 AM
Post
I used a piece of threaded rod, a few pieces of pipe and some big ass washers, and made a tool to press the bushings in.
ZZ69chevelle is offline
post #4 of 4 (permalink) Old Jun 14th, 04, 9:00 AM
Post
If my feeble ol' brain serves me, I think I put the sleeve in part way and then put the trimmed down ring over the end of the sleeve and then press it the rest of the way in. Ummm... too long ago.....
Cam
Cam Sweet is offline
This Thread is more than 5833 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
