Lowering Questions. - Chevelle Tech
post #1 of 16 (permalink) Old Jun 11th, 04, 1:33 AM Thread Starter
Send a message via AIM to BW72
Post
I followed a white 72 SS 'velle up over Cannon St. in Anaheim Hills 2 days ago and liked his stance. It made me consider lowering my 72 velle. I wanted to catch up with him and ask him what his setup was, but never got the chance.
Anyway, I looked around in here and found that most people say to avoid the 3" drop (which is what I think he had).
I'm considering 2" coil drop all around. I'm running 15x7" Corvette (I think) rallys with 235/60 R15s (not sure of the backspacing). Would this cause rubbing or other problems? Would 2" be too low for this setup? I'm considering increasing rim and tire width in the rear eventually as well, but not for a while.
My exhaust won't be an issue, I'm going to put manifolds back on and new exaust piping until I can get some short headers.
Thanks guys!
-Bryan<br />1972 350-Malibu<br /> <a href="
target="_blank">http://www.westcoastforums.com</a>
BW72 is offline
post #2 of 16 (permalink) Old Jun 11th, 04, 4:08 AM
Post
i did a 2in drop on springs and it sits ok. havent driven it so i dont know the real height.
jocww is offline
post #3 of 16 (permalink) Old Jun 11th, 04, 6:17 AM
Post
I dropped mine 2" and don't have any rubbing issues with 235/60/15's in the front and 275/60/15's in the back. It could be affected by your backspacing though.
ZZ69chevelle is offline
post #4 of 16 (permalink) Old Jun 11th, 04, 9:49 AM
Post
I used the 2" drop spring from OPG and 17x8 wheels. No rubbing!
kamino69er is offline
post #5 of 16 (permalink) Old Jun 11th, 04, 10:42 AM Thread Starter
Post
Thanks guys, just what I wanted to know!
The rallys I'm running are original corvette rallies I believe (4.5" backspacing??) and I haven't had the opportunity to check their backspacing. I'm going to have to do that.
"kamino", nice ride! I was hoping someone would post a pic with a 2" drop so I could see what it looks like. Is there much difference in appearance/height between a 69 and the 70-72's with the same drop?
BW72 is offline
post #6 of 16 (permalink) Old Jun 11th, 04, 3:01 PM
Post
2" drop springs will work fine but if you want a lower front ride height,those 235/60's are a little tall.
Clint44 is offline
post #7 of 16 (permalink) Old Jun 11th, 04, 6:35 PM
Post
Kamino, that stance is BAD! I like. What size tires are you running?
Bacchus is offline
post #8 of 16 (permalink) Old Jun 11th, 04, 8:34 PM
kevin
Post
hey Kamino,
using the opg springs, how does it ride??????
have you had a chance to ride in one with hotchkis springs????
if so, can you tell a difference from your car to the other?????
thanks,
Kevin
kev69350 is offline
post #9 of 16 (permalink) Old Jun 12th, 04, 5:03 PM
Post
if you say 235 60s are too high for a lower stance what would you suggest; a 50 series tire?
69chevelle69 is offline
post #10 of 16 (permalink) Old Jun 12th, 04, 9:48 PM
Post
So nice, kamino.
doggy69 is offline
post #11 of 16 (permalink) Old Jun 13th, 04, 12:14 AM
Rob
Post
I run 235/60/15's front and 255/60/15's back with OPG 2" drop springs in front. Rear springs are sagging a bit. In this pic the trunk was full with travel gear. I have full length Dyno-Max headers, and have MAJOR clearance issues with the drivers side header. 235/60 is as short a tire as I would want to go.
17Again is offline
post #12 of 16 (permalink) Old Jun 13th, 04, 12:16 AM
Post
That or maybe something like a 215/60/15 tire.
Clint44 is offline
post #13 of 16 (permalink) Old Jun 13th, 04, 12:49 AM Thread Starter
Post
Here's how mine sits now.
Although I kinda like the slight raked look it has, it looks like it sits too high in the back, making the 235/60's look skinny when you're looking at it from the rear.
BW72 is offline
post #14 of 16 (permalink) Old Jun 13th, 04, 12:10 PM
Jerry
Post
I have Hotchkis 1" lowered springs and it seems low enough for me. Especially in the rear.
mild68ss is offline
post #15 of 16 (permalink) Old Jun 13th, 04, 6:53 PM
Post
As far as ride goes, I'm very happy with it. Although Hotchkis springs my be a better ride.
I am using a BFG's 245/45/17 tires in the front.
This Thread is more than 5837 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
