PST Front End Kit install, dialup warning - Page 8 - Chevelle Tech
post #106 of 120 (permalink) Old May 19th, 13, 10:35 PM
Brandon
Re: PST Front End Kit install, dialup warning
After a 7hr alignment, it's finally road ready.
ID:	84545   Click image for larger version
Todd79 is offline
post #107 of 120 (permalink) Old May 20th, 13, 12:33 AM Thread Starter
>>> 7 hour alignment
OMG, guy ever align a real car before? Tell him the MacPherson struts are in the trunk.
post #108 of 120 (permalink) Old May 20th, 13, 12:34 AM Thread Starter
Glad to see you're up and running. Car looks good and the springs will settle some, they always do.
post #109 of 120 (permalink) Old May 20th, 13, 10:23 PM
Brandon
Ha ha ha thanks man. I was calling around asking other places how long they take. Glad they only charged me the standard $60. Hope it doesn't sit down too far. Thanks for all your guys help!
Todd79 is offline
post #110 of 120 (permalink) Old May 22nd, 13, 7:33 PM Thread Starter
you oughta stop by there with a case of beer or something for that guy. They usually don't get any hourly wage, just a part of the labor for the job. He probably has a bad week from only making $30 working on your car.
post #111 of 120 (permalink) Old May 24th, 13, 10:28 AM
Brandon
Yeah, I was kinda thinking the same thing..
Todd79 is offline
post #112 of 120 (permalink) Old Jun 2nd, 13, 12:28 PM
Hy guys, got the replacement springs put in my 66 yesterday (PITA). The top pigtail seems to sit where it needs but the bottom sits back from its normal position in the LCA. Basically behind the first hole. Think this will be okay in the grand scheme of things? I'd REALLY rather not mess with those things again....
Simon
SimonGBarr is offline
post #113 of 120 (permalink) Old Jun 2nd, 13, 3:30 PM Thread Starter
isn't the top sort of flatwound? align the bottom, it will really affect your ride height if it's off.
post #114 of 120 (permalink) Old Jun 2nd, 13, 3:42 PM
Tom, the tops are as round as the rest of the coil. I know what you're referring to, but these are not flat, nor were the originals.
Simon
post #115 of 120 (permalink) Old Jun 2nd, 13, 3:52 PM Thread Starter
there's a difference between flat wound and flat ground. My 70 front springs are flat wound so the top coil isn't as tall as the other and they're flat ground like a valve spring.
couple days ago I was looking at AzCamino's 66 front springs, they were flat wound and pigtailed at the top but no grinding. The spring wire was still round.
post #116 of 120 (permalink) Old Jun 2nd, 13, 4:01 PM
Ah, I see now. Then, yes, flatwound. lol. Thanks Tom.
Simon
post #117 of 120 (permalink) Old Aug 1st, 13, 11:05 AM
Dennis
Just thought I would chime in here on PST. I just attempted to order some things from their website. They were advertising some specials, 15% off front end kit, $20.00 off tie rod sleeves with purchase of front end kit yadda yadda yadda. When put all this plus a rear end kit, and springs in my cart, the discount didn't show up, even on the credit card page. So I attempted to use the online chat to ask some questions. It doesn't work. No surprise there. So I call up. The "sales" rep did his best to make sure that I knew he was annoyed by inquiries. He then proceeded to tell me that they just "take if off" after you submit the order. Now I don't know about you guys, but before I pay for something, I like to know what it's going to cost me. Tax, shipping the whole thing. Well Needless to say, I will get my parts elsewhere.
Just wanted to let you guys know my experience, hope this helps someone else out.
EDIT: Just and FYI, you can see a partial discount on the CC page, but not your total discount. There is still some blind faith involved. That doesn't change the service aspect, or lack there of in this case.
Deisel23 is offline
post #118 of 120 (permalink) Old Apr 20th, 15, 9:23 PM
Hi -- I started a project to replace the drum brakes with discs on my 1970 Chevelle...and it ballooned into a complete front end rebuild. I came across this post and decided to give the PST kit a try for myself. I decided on the Original and not the Polygraphite.
I am currently at the point of installing the idler arm, cross link, and tie rods. I have everything hooked up but have run into what appears to be some fitment issues.
First, the grease zerks for the inner tie rod ends are pointing directly into the lower control arms so there is no way to connect a grease gun to grease the joints. I swapped out the straight for 90 degree zerks. But this then brought me to a bigger issue.
The second 'bigger' issue is that the inner tie rod ends are VERY close to the lower control arms. So much so that when I put in the 90 degree zerks, I can't turn my steering more than about 1/8th of a turn before the zerks hit the control arms. And I notice that the center link also appears to be almost sitting on the front cross member.
The two things that are different from this write up and my project is that I installed 2" drop spindles and replaced the stock steering box with a CCP 500 Series.
In one of the photos posted here, you did comment on how tight things were. Did you experience any fitment challenges? What was your experience with the grease zerks?
This is the frontal view:
This is sighting down the tie rod on the right side:
This is a closer view of the tie rod end, following down the tie rod from the previous picture:
The wheels are currently centered. Notice how close the zerk is to the cross member and project it's path. Also notice that the tie rod end itself is directly in line with the cross member. It almost feels like the center link is not installed correctly.
Any thoughts or ideas would be appreciated.
Thanks -- Jeff
Here are the parts I'm using for my project:
  • PST Super Original Front End Kit (FEKSSOLD691)
  • PST Pitman Arm (PIT19506)
  • PST Center Link (TRE749)
  • Front Coil Springs (MOG-5390)
  • Summit Racing Drop Spindles (SUM-BKA24800DS)
  • CPP 500 Series Steering Box (CP50004)
jgbrown is offline
post #119 of 120 (permalink) Old Apr 29th, 15, 4:51 PM
Update: I reverted back to the small, straight grease zerks and everything clears. It is definitely a TIGHT fit.
Thanks -- Jeff
jgbrown is offline
post #120 of 120 (permalink) Old Apr 29th, 15, 7:04 PM Thread Starter
yes it is. I have mine poking straight out the back. I have to turn it lock to lock or close to it, bring the grease gun hose in over the top of the lower control arm.Some inner rod ends are sold with the zerk pointing straight out to the inside. Automatically pokes holes in the oil pan at full lock.
This Thread is more than 1892 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
