Dislocated Rear Coil Springs - Will it affect the ride? - Chevelle Tech
post #1 of 5 (permalink) Old Feb 20th, 01, 6:56 AM Thread Starter
My rear coil springs are halfway off their pockets and I was wondering if this will cause the car to ride rougher. I plan on getting them fixed in the spring, and add rubber insulators too.
Again, to put them back in place, all I have to do is jack the car up, remove a wheel, unbolt a shock, and then put the spring back in place and put it all back together? Is that how it's done? Thanks for the help!
1970 Chevy El Camino (Custom) Non-SS
Will be Green Mist & Silver w/Green Vinyl Top (now black)
350ci/300HP 4bbl & Dual Exhaust
TH-350 - 2.73 Posi Rear - Factory PS, PB, PW, A/C & More
My El Camino Home Page
Owner - 1969 Snowco Trailer
Team Chevelle Member #995
"..dreams turn into dust and blow away"- Dionne Warwick (1968)
Shawn is offline
post #2 of 5 (permalink) Old Feb 20th, 01, 7:18 AM
Doug
Shawn
It's about a 5 minute job. You don't need to remove the tire, just unbolt the lower shock and jack up the body. Use a pry bar or tire iron to pop it into place. Either jack up the car (quickest) or put the frame on jack stands and lower one side of the differential at a time.
Doug, Chevl71
Team Chevelle member #625
Gateway Area Chevelle Club member CM028
chevl71 homepage
chevl71 is offline
post #3 of 5 (permalink) Old Feb 20th, 01, 7:34 AM Thread Starter
Thanks Doug, I'll give it a try. I might have to remove the wheels anyway since I don't think my jack goes up high enough.
Shawn is offline
post #4 of 5 (permalink) Old Feb 20th, 01, 12:52 PM
Doug
Shawn
I did a quicky spring sway on a Monte and used the floor jack on the frame just in front of the rear end. Worked great.
Doug, Chevl71
chevl71 homepage
chevl71 is offline
post #5 of 5 (permalink) Old Feb 20th, 01, 5:40 PM
I have 1 1/2 inch lowered springs and I have to reseat them every time I lift the rear off the ground even with the shocks and airbags in them! It really is a 5 minute job!
Redrum (or Mike)
68 Corvette - 383 CI 427 HP
69 SS Chevelle being updated to Pro-Touring
97 Z-28
Redrum is offline
This Thread is more than 7075 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
