Spring Removal - Step By Step - With Pictures - Page 3 - Chevelle Tech
 3Likes
Closed Thread
post #31 of 62 (permalink) Old Apr 24th, 09, 2:32 PM
Re: Spring Removal - Step By Step - With Pictures
I just changed my fronts last weekend. I own an internal spring compressor and used an impact to tighten the tool.... stripped out the threaded part of the tool. I went out and rented a tool - internal spring compressor - and used the ratchet to tighten it.
I compressed the spring after removing the shock. Once the spring was compressed, I then dismantled the lower ball joint and went from there using a floor jack to lower the control arm. At all times I kept myself out of the line of fire should the compressor fail.
The assembly was the reverse of the dismantle. I did not use a chain.
Stalkingbear is offline
post #32 of 62 (permalink) Old Apr 26th, 09, 12:39 PM
great thread.
It reminds me of the days of pulling springs to find that perfect ride height. Thank god for coilovers!
As for the chains, I was a young mechanic once, and was attempting to pull springs from a car without any chain, or method of holding in the springs. One shot out and hit me square in the chest, knocking me on my arse. Bruised ribs, and a bruised ego were my lesson plan, and I learned right then and there that isht happens. Now it's all about the safe way to do it.
I saw a guy grinding and welding without any protection once, while visiting Tijuana.
Think about it.
67' Beaumont - "the driving project"
06' Subaru STi - "the fast car"
hypa is offline
post #33 of 62 (permalink) Old Apr 26th, 09, 11:01 PM
Don
I leave the ball joints connected and remove the lower control arm bolts, then let the jack down. just as easy going back with the spring too.
dgwar is offline
post #34 of 62 (permalink) Old Apr 27th, 09, 2:21 AM
Ryan
very nice write up!!!!
ryan
my 67
rchevellea is offline
post #35 of 62 (permalink) Old Jun 6th, 09, 5:43 AM Thread Starter
Team Chevelle
Thanks.
I'm going to put up another similar thread when I reinstall new springs.
-Greg
All Great Truths Begin As Blasphemies.
Greg is offline
post #36 of 62 (permalink) Old Jun 7th, 09, 1:15 PM
Won't get into the chain debate, nor offer how I do it... but I will offer a time-saver:
In regard to removing the front shocks.... if you're not going to reuse them...
Up here in rust country, trying to remove the upper nut off the shaft will take longer than the entire spring change! Try this instead:
Get the correct sized deep-well socket (six-point preferred) and a 1 foot extension. Push it down on the nut & stud and just reef back & forth on it until the shock's shaft snaps off. It'll always snap somewhere under the nut inbetween the rubber biscuits!
Try it next time! It'll save you at least 1/2 hr. per side.
Member -
"Think you used enough dynamite there Butch??"
John D is offline
post #37 of 62 (permalink) Old Jun 7th, 09, 3:03 PM
I used the threaded rod with nuts and home-made washer for the bottom method. Worked great, although after 2 spring installs, the threaded rod was just about stripped of its thread as it was regular every day allthread with no heat treating to make it harder.
As said, in theory this is a much safer method but as long as the other methods work and safety precautions are taken they will work as well.
1967 Chevelle Custom
SBC 383
Gear Vendors Overdrive
Jerico DR-4
S60, True Trac, 3.54 gears
cobaltchev67 is offline
post #38 of 62 (permalink) Old Jun 8th, 09, 2:02 PM
Antti
Thanks Greg, very useful info. Perhaps the mods could make it a sticky thread. I'm in the middle of pondering whether to do it myself or take it to
a shop. Pls hurry with your installation thread
-64 Chevelle convertible
Anders is offline
post #39 of 62 (permalink) Old Jun 29th, 09, 5:20 PM
Fredrik
I write in this thread in stead of making a new one. One question when you put the spring back again it says in the Chevrolet manual (Chevelle -72) that the end of the spring should be over the hole in lower control arm. I have two holes in my lower control arm. How import is this and does anybody know witch hole it should be over. Take a look on my picture, it is right side of the car. Back is right on the picture. Hope you understand.
Fredrik is offline
post #40 of 62 (permalink) Old Jun 30th, 09, 12:14 PM
you just want to get both springs somewhere between the 2 holes in each arm so they are close to the end of the pocket they rest in. If you were off a little and wanted to turn it in place, you could use a little oil on the lowest part of the tail and a good leather strap wrench around one of the middle coils. It looks like from your pic you are in between the holes already so if I'm seeing that right you shouldn't need to move it.
rickster182 is offline
post #41 of 62 (permalink) Old Jun 30th, 09, 3:38 PM
Fredrik
Thanks for the information Rickster182. A just found Tom Mobley stickey thread, he explain that the end of the spring should be between the two holes.
Fredrik is offline
post #42 of 62 (permalink) Old Sep 27th, 09, 2:23 PM
Jason
Complete noob question: in picture #8, it looks as if your brake lines are disconnected. Is this a mandatory step in the spring removal process?
FWIW, I have front power discs.
Thanks, and great thread!
jkratty is offline
post #43 of 62 (permalink) Old Sep 27th, 09, 8:30 PM
rkd
Ron
I would add to this thread that removing, and especially installing, front coil springs can be vastly different with stock springs and shorter or cut springs.
In both my Chevelle and in Fox Mustangs, a shorter, cut, or performance spring will be much easier to get out and in than a tall stock one. Stock ones are a bit-h and may be best done with an internal compressor. Note that I have snapped a 1/2 in threaded rod in an internal style spring compressor, and upgraded to 5/8 rod.
When removing the front ones from the Chevelle, which I have done twice, I have not used the chain. Both times, after getting the lower arm down, the spring stuck in the pocket with the jack all the way down.
Some careful crowbar work will just pop it out and it flops on the ground.
I stand at arms length with the jack when going up or down. I also like some 2x4 blocks to catch the arm if the jack leaves town in a hurry.
I would suggest removing the shock, sway bar links, etc before the ball joints. I don't like fooling with that stuff with a compressed spring near my fingers.
Going back in, I was able to put the spring in the upper pocket and control arm by hand with no compressor, then jack slowly.
I have tried the chain technique, and would, if possible run the chain down through the center of the control arm if possible, if you use that method.
rkd is offline
post #44 of 62 (permalink) Old Feb 17th, 10, 5:36 PM
So you loosen the upper castle nut but never take it off completely?
1965 SS
PO was a POS
Brettd85: I feel so bad for datapusher, he just cant get a break with this car.
novaderrik: who the hell puts a car together like that?
datapusher is offline
post #45 of 62 (permalink) Old Feb 17th, 10, 5:45 PM
This is to use the spring and car weight to help pop the balljoint taper out of the spindle. Once the BJ is popped, then you remove the castle nut and move on with lowering the floor jack lessening the tension of the spring, ect.
'69 SS396 - FiTech L33 swapped w/Muncie, 3.31 TrueTrac - VHX Gauges.
Originally Posted by Busted Knuckles View Post
Being politically correct is kinda like trying to pick up a turd by the clean end.
GenPac is offline
Closed Thread
This Thread is more than 3216 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
