Front End Track Width - Chevelle Tech
post #1 of 8 (permalink) Old Apr 15th, 06, 5:38 PM Thread Starter
Question Front End Track Width
How much wider does converting from drum to disc make the spacing between the front wheels? I just put on CPP Disc front brakes and now I have slight rubbing of the passenger's front tire when I make a left hand turn. It is rubbing against the front of the fender lip bottom at the front of the wheel opening. I have B. F. Goodrich Radial T/A P225/70R15s on the front. Never had this before the conversion.
67 Nevada Chevelle is offline
post #2 of 8 (permalink) Old Apr 15th, 06, 5:48 PM
Re: Front End Track Width
I installed a Right Stuff kit on my 65 this winter and it ended up about 3/16" wider per side. Of course they told me it would not change at all
guess I talked to the wrong guy!
Jeff Evans
65 Chevelle, LS3/T56 transplant in progress
67 Chevelle, ZZ502, AFR 305, Straub Solid Roller, 400 Turbo, Moser Rear 3.42 gear
Jeff65SS is offline
post #3 of 8 (permalink) Old Apr 15th, 06, 6:25 PM
Big D
225/70R15's is pretty narrow... I have 255's in the front and some have wider...
ChaosEnvy is offline
post #4 of 8 (permalink) Old Apr 17th, 06, 3:36 AM
yes discs will add a slight amount.
on my wife's '67 Firebird, i had to step down one size on the front tires after the swap.
went from 225/60-15 on 8" wheel to a 215/60-15
no rub at all now.
INJUNTOM is offline
post #5 of 8 (permalink) Old Apr 19th, 06, 1:26 AM Thread Starter
Thanks for the comments. The rub is very slight just as the tire is moving left, right at the bottom of the fender. Think I will get out the grinder and see about taking just a slight amount off at that point. The touch is so slight there is no mark on the tire, but as you well know, it makes quite a noise in the car. Also found the passenger side is ~ 1/2' lower than the drivers side. Any way someone knows how to easily raise one side ~1/2"?
post #6 of 8 (permalink) Old Apr 19th, 06, 12:11 PM
I measured a 69-72 A-body disc setup versus a 66 Chevelle drum setup and calculated right about 1/2" wider (each side) for the disc setup...
I measured two spots:
1) from the "wheel" mounting surface out to the tip of the spindle(dust cap off).
2) from the wheel mounting surface to the edge of the upper control arm...
TC #1366
Sold
Sold
1966_L78 is offline
post #7 of 8 (permalink) Old Apr 20th, 06, 12:13 AM Thread Starter
Thanks Tony. That is about what I measured when I finally got out the old spindles last night and measured the from the center of the spindle mounting bolts opening on the control arms to the base of the rim mounting studs. That is just enough to cause the slight rub I have. I am still looking on how to EASILY raise the front passenger side of the body (fender) up ~1/2". That would give the little extra space I need.
post #8 of 8 (permalink) Old Apr 20th, 06, 11:29 AM
I wouldn't just add spacers to the body without checking to see if the front spring installation isn't causing your problem. When I installed new springs, I had to trim about an inch off the bottom coil to get it to sit in the perch the way it should ( top and bottom ).
66PetRat is offline
This Thread is more than 5161 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Lowering Front End on 65 KMD Brakes, Suspension & Steering 0 Feb 18th, 06 9:29 PM
front end has drivers side lean and pass side bushings creak? hilljack Brakes, Suspension & Steering 6 Nov 4th, 05 6:55 PM
High front end mac762 Brakes, Suspension & Steering 6 Oct 6th, 05 6:08 PM
Front end CITY GIRL Brakes, Suspension & Steering 7 Sep 18th, 05 7:35 PM
Rebuild Front End Jm70SS Brakes, Suspension & Steering 5 Sep 1st, 05 10:14 AM
