Convert to power steering. - Chevelle Tech
post #1 of 8 (permalink) Old Aug 1st, 20, 10:15 AM Thread Starter
steve
I have a 67 big block I want to convert to power steering. It has a short water pump. Any one make a kit. I don't want the separate pump tank, I want a one piece setup.
67 GTO more Chevelle than Pontiac.
427stingray is offline
post #2 of 8 (permalink) Old Aug 1st, 20, 10:53 AM
Bruce
Re: Convert to power steering.
That's a very simple mod. Any of the parts supply houses can fix you up with the various factory-style pieces you'll need.
Check your assembly manual for what parts you want.
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 8 (permalink) Old Aug 1st, 20, 11:48 AM
Marcus
https://www.ss396.com/chevelle/PSKIT-S67.html
Std ratio
https://www.ss396.com/chevelle/GBK-1A.html
Fast ratio
https://www.ss396.com/chevelle/GBK-1SFA.html
Pitman arm
https://www.ss396.com/chevelle/F-6467.html
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #4 of 8 (permalink) Old Aug 1st, 20, 12:56 PM
Do yourself a favor and transform your car by installing the Lee set up. Use the brand new 800 Series box and have them blueprint it. I have a 14:1 ratio with a 20 pound valve that's perfect! It feeds back and returns after a turn like one of the better performance manual box's but has power assist for parking.
I got the 14:1 ratio because I wanted more centering crown for relaxing highway driving..
Those boxes above me, the fast ratio is 10:1. that would be a handful on the highway at 90-100 mph..
hydro462 is offline
post #5 of 8 (permalink) Old Aug 1st, 20, 3:27 PM
Ken
Thumbs up Re: Convert to power steering.
64-67 A body kit from CPP.
https://www.summitracing.com/parts/clp-cpp6467psk
You will need a pump bracket and pulley when converting from manual steering.
You can get them from March brackets and pulleys.
I have a CPP kit in my 1970 Chevelle and it works great, Converted from manual steering and one of the best updates I ever made.
ken70ss396 is offline
post #6 of 8 (permalink) Old Aug 2nd, 20, 7:32 AM Thread Starter
steve
Yes i have been looking at the kits for a 67. They have the separate pump reservoir. I want to put a one piece pump on it.
post #7 of 8 (permalink) Old Aug 2nd, 20, 11:51 AM
Marcus
I think Alan groove is your best option for brackets then.
http://www.alangrovecomponents.com/B...Short_Pump.htm
Pictures and more info in this thread.
https://www.chevelles.com/forums/13-...cs-inside.html
post #8 of 8 (permalink) Old Aug 2nd, 20, 1:59 PM Thread Starter
steve
Thank you for the links and the pictures. I just wanted to take the guess work out of it and get it right the first time. I have done the swap on other cars. Most recently my 72 Corvette.
